Question about AT&T SB67118 1-Line Corded / Cordless Phone
Base won't keep correct date & time - AT&T SB67118 1-Line Corded / Cordless Phone
In my nokia e63 it is saying that incorrect date and time but my date and time is correct
Confirm the month, date, year, & time is correct. If it still shows correct, try power cycling your phone and when it comes back online, confirm the error is gone and you still have the correct date & time.
Jul 31, 2016 | Nokia Cell Phones
How do I set the time and date?
Have you manually set the date and time?
You can also turn the first option under Date & Time-Automatic-to On to have an online master timekeeper set the correct date and time on your Fire. Even if you occasionally go offline (for a car trip, say), the Fire's internal ticker keeps things on track.
Dec 27, 2015 | Amazon Kindle Fire HD 7in, 32GB
BT Aura 1500 Quad telephone - calls list freezing
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Jan 15, 2013 | Lands Phones
Wrong date & time on motorola
maybe your time setting by region is not correct so go in settings and update. if you explain which is your model of motorola i could help in more details.
Jun 22, 2012 | T-Mobile My Touch Cell Phone
How can I remove automated date & time update?
Hi First try to Restore it by selecting Restore Only from the phone setting.After successful restore setting is done please check the time setting.Good luck
Feb 13, 2012 | Nokia Classic 2330 Cell Phone
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
HOW DO I SET THE DATE & TIME ON THE ANSWERING MACHINE DS6221-1
Hi there, I found my manual that states:
Press MENU/SELECT to display menu when in idle mode.
Press the up or down triangles to reach DATE/TIME. Press MENU/SELECT.
Use the keypad to set the year. Press MENU/SELECT.
Use the keypad to set the date. Press MENU/SELECT,
Use the keypad to set the time. Press the up or down triangles to select a.m. or p.m. Press MENU/SELECT
The screen displays STORED and you'll hear a confirmation beep.
George Rocks
Apr 18, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Wharfedale DECT TAM telephone/answer machine is flashing CL on the main answer machine base unit. This message is not indicated in the user manual can you please advise? Many Thanks Steven Clifford
This is due to the base unit losing power and needs the clock resetting.
The handsets retain their clocks under battery power so this is a little misleading.
To reset the base unit clock:
- press the OK key
- press the 'down' arrow twice until "DATE/TIME" is displayed.
- press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
- The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
- The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
- The handset then beeps and displays "SAVED".
- Press the "C" button and replace the handset on the base unit.
The base unit should now stop flashing "CL".
Aug 28, 2008 | Emerson EM-CKT9087 Corded Phone
IN 120 base keeps flashing CL
- press the OK key
Jul 09, 2008 | Lands Phones
AT&T SB67118 1-Line Corded / Cordless Phone Logo
46 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
