Question about Frigidaire Dryers
I need a wiring diagram For Frigidare FLXE52RSB6 Had a new tub bearing put in washer runs but dryer dead
  • 1,998 Answers
Http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fY2704613-00008.png here is the wiring diagram that you were asking for if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future in similar situations Thanks Rick
p.s click that link
Posted on Apr 08, 2011
Why does my Frigidare crown dryer runs smooth when starts up, but gets a noise that gets louder the longer it runs it runs
Either your drum bearing or drum felt kit is worn out. It is always better to put drum bearing along with new drum felt kit.
Dec 05, 2014 | Dryers
Washer wiring diagrams
Heating element, washing motor and bearing must be earthed.
Dado
Sep 02, 2014 | Electrolux EW1200i Front Load Washer /...
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Final spinning cycle makes very loud noise.
sounds like you have the dreaded bad tub bearings. Does it sound like an aircraft taking off? Open the door and lift the drum and see if you feel any play.
I don't know your technical ability, but you can match up bearings and a seal and repair it ( frigidare will only sell you the complete drum with bearings) but its a big job as appliance work goes. You will have to decide how to proceed from there as far as fixing it or buying a new one.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
How do you put a drum bearing toghether for dryer
inside of dryer on right use allen wrench to remove old bearing. lift on tub to insert new bearing.
Jun 20, 2009 | Fisher and Paykel DG05 Gas Dryer
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
Frigidare Washer Drum making noise when in spin
it is your bearings you need to replace both tubs and the basket but it will be cheaper and easier to buy a new machine to rebuild your washer it a pain in the **** because you need to take the whole machine apart. if you do decide to rebuild it make sure that you have someone else there to help the tub is bulky and has some weight to it
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
Leaks water
Okay, to check for your source of a leak, start by removing the 2 screws on the lower front panel of the machine. This will let you see inside. As you are running the washer, watch where the water is coming from. If from the front, you may have a hole in your boot (the black rubber up front) If so, you may need to replace the boot (the part comes with step by step instructions). If coming from the middle, your tub seal may be going bad. A quick fix is tighten the 12 or 14 bolts that go all of the way around your tub. This will only be a temporary measure. The tub will have to be taken apart and the seal replaced. (this is a 1 1/2 hour - 2 hour procedure for 2 technicians) If it leaking from the rear, you may have a bad tub bearing. You can remove the back panel to be certain, but usually a bad bearing will be accompanied by a roaring noise durring the spin cycle. As for the dryer leaving brown marks? Usually the front seal has been dammaged. Run your finger around the front of the drum (where it meets the front panel) the gap should be about the same all of the way around. If it is not, you may need a new front seal. (this is much cheaper and less time consuming on the dryer compared to a seal on the washer)
Jun 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore Washer/Dryer Combo purchased in late 2000
Call a local repair tech. I know one in Milwaukee :)
Seriously, your machine needs some possibly expensive repairs beyond a novice's skills. The dryer has a felt bearing around the front of the drum that is probably worn out. Check on the rear bearing and the belt at the same time. The washer may need a new transmission, belt, tub seal, and spin bearing. That's an involved repair. Expect to pay extra for labor, but the total bill should be less than the $800 - $1400 for a new machine.
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
19 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
