Question about Electric Strider Mini 4 Wheel Mobility Scooter Cherry
I have a brand new scooter the batteries wont hold the charge
  • 692 Answers
Bill have them replace the batteries. They are under warranty for 6 months and the provider is responsible for providing free replacement batteries under warranty. If they won't contact the manufacturer of the chair and explain your problem (that the provider will not replace bad batteries) they should require the provider to give you new batteries or send some to you. Make sure that you charge the new batteries before use and that you charge them nightly for 20 days If you use the scooter daily charge it every nite when you go to bed and unplug it in the morning hen you get up. Remember to have the power off to the charger whenever you plug or unplug it from the scooter. if the charger is an onboard one then just plug it into the wall and unplug when charged Hope this helps
Posted on Apr 09, 2011
4 Suggested Answers
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
gewiz
  • 1263 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
  • 61 Answers
SOURCE: battery won't hold a charge
More than likely duff batteries. Will it hold its charge if the batteries are taken off the scooter (i.e. remove the battery pack)? If so, it could be a short somewhere in the wiring of the scooter although I would have to say that this would be unlikely.
Posted on Mar 19, 2010
Why does my 150 cc SUNL scooter not hold a charge? New battery is no different than original. It is a 2008 with 26 miles on it
Doesn´t matter the miles runned.
The battery is too old. chemicals inside are not capable to hold Current(Amperes).
Yo must change the Battery by a New one with the same parameters. (Volts,Amps, Size.)
2008 from now it´s too much time for a Battery, even unused.
Oct 21, 2014 | UPG 12V 12Ah SunL Tiger Scooter Battery -...
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Battery wont charge
could be to hold not holding charge anymore.
Mar 19, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
Wont hold a charge. Batteries checked out ok. Could it be a short? Is this common?
If the batteries have been volt tested OK and they wont hold a charge, check your charger to make sure it is functioning properly. If there was a short, the scooter most likely would not work or would give a flashing light code. Batteries typically will not hold a charge when they are damaged, have been sitting unused for a while or if there is a mechanical issue that is causing dtrain on the motors. Check the air pressure, bearings and ensure there is no noise or vibration that may indicate a motor failure. If all those check OK, replace the batteries.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Schwinn S400 no power
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are probably available at:
http://www.electricscooterparts.com/schwinnscooterparts.html
Jun 17, 2009 | Transport Schwinn Rechargeable Portable ...
Electric Strider Mini 4 Wheel Mobility Scooter Cherry Logo
101 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
