Question about Dishwashers
My hotpoint dishwasher does not work. Looks like the timer
    Master:
  • 354 Answers
I would check the door awful closely cause that is 90%f the problem. If that door switch isn't making nothing works
Posted on Apr 08, 2011
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
My dishwasher doesn't work. It won't clean the
It can be your timer, motor, or water value. I need more detail information.
May 13, 2011 | Hotpoint HDA3520ZBB Dishwasher
Hotpoint dishwasher. Is the timer out?
maybe the float is sticking. did you check the float switch?
Aug 19, 2009 | Dishwashers
Fault code AL10
I called an engineer after checking with hotpoint what the fault code was. Hotpoint advised that it was either a faulty heating circuit and I had to check the heating connections and timer (impossible unless you call an engineer).
Anyway, the fault turned out to be something to do with a water feed (I can't remember the technical name). There wasn't enough pressure coming through a particular valve as it was stuck in a semi-closed version, consequently the heating element wasn't switching on as it wasn't 'sensing' enough water pressure.
Valve has been fixed, and the dishwasher is now doing OK! For the time beginning at least.......
Jan 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint bf162 built-in dishwasher error codes
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint df32
REPLACE WATER INLET SOLENOID ON WASHER
Jan 16, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
