Question about Garden
How would I install and e-ring on a brinly lawn roller?
    Master:
  • 354 Answers
E-clips come off verycarefully with a flat head screwdriver,have a rag over top to knock it down if flys off. Installing just put on one sie than the other with needle nose pliers and a flathead screwdriver
Posted on Apr 08, 2011
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
Yamaha MT110 engine assembly
I can't speak for the governor, but I can't IMAGINE that any crankcase roller bearings would be sealed - they need all the lubrication they can get.
Apr 21, 2014 | Garden
Need owners manuel for dayton chain saw model 3z192
owners manual is kind of generic, this is a old saw . what do you need to know ? if you need help your local lawn mower sop could be a big help, brin in the saw with you and ask away.. Jay
Nov 03, 2013 | Garden
Replacing drum rollers how to install
Gain access to the drum buy uninstalling the front panel.
  1. Remove triangle shape retaining ring.
  2. Slide off roller.
  3. Install new roller and retaining ring
Dec 07, 2010 | Dryers
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
How to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Toro Lawn Mower With Toro Power Tools
Bushings
They don't have to be made by the same company that made the aerator. Take one bushing off and visit Ace or Home Depot. I would replace them all at the same time. But all you need to do is find the physical match and go from there.
Nov 02, 2009 | Brinly-Hardy Brinly Hardy Company 40" Tow...
Changing the wheels
The drum roller is held in place with a TRU-ARC snap ring, which looks like a C with 2 small holes in each end of the C. This is located on the front of the roller shaft and can be difficult to see. These ordinarily require the use of a TRU-ARC snap ring tool. However, I can guess that you don't have this tool, so, a putty knife, butter knife, or other thin blade, dull, tool would suffice Carefully wedge the blade in between the ring and the roller and gently twist the tool to force the ring out of the groove that it snaps into DON'T lose this ring! Slide the old roller off the shaft, clean and lubricate the shaft with Poly lube, slide the new roller on and reassemble. Of course the snap ring will have to be partially inserted into the groove, and forced the rest of the way with something like a ratchet wrench socket that fits against the ring,(not over it), and push to engage it back intio the groove.
Hope this helps! Repost me if you need more assistance,
Dave E. (Illeagle)
Jun 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Garden Logo
194 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
