Question about Dryers
My dryer will run but not heat. Was looking for the element but dont know how to get to it. Can you help
  • 413 Answers
Depending how old it is, some have a small door down at the bottom in the front. Others, you have to take the front off the dryer and you will be able to get to everything. Unplug it first before you try this. There may be at least 4-6 screws holding the front panel on.
Posted on Apr 08, 2011
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Tumble dryer working but no heat no matter what settings
in 99% of the case its the heating element take the dryer apart and run your hand around the element in most cases the burn causes a burn/blemish on the element a dangerous but simple way to check if you dont know how to use a multimeter is to run a power cord dirrect to the two points on the element polarity ( positive negative) does not matter if the element does not start to heat up its blown / replace it
best of luck
merry christmas
Dec 21, 2010 | Hotpoint Dryers
Dryer does not heat up
Unplug the dryer. Look for blockage.4b24ab7.jpgIf you have air restrictions your heater element might be OK. 142c967.jpga4caa20.jpgIf all these components check good and you still don't have heat you might have a timer problem or an electrical problem. The timer has a leg going directly to the heater element. The load is high and overtime the contacts inside that timer get burntc97b4dc.jpgAnother thing it could be it the breaker. The motor runs on 120 volts. The heater however runs on 240 volts. If the breaker is worn on the heat load side then the dryer will work but their will be no heat.7e5d468.jpgIf it turns out to be a limit instead of the heater element then clean out the dryerd60b014.jpg8006b2f.jpgb57aa0b.jpg0fe9a0b.jpg3aea907.jpg2b993f6.jpgService manual for kenmore
More Here
Aug 04, 2010 | Kenmore 64742 Electric Dryer
I have Jenn Air Elctroc dryer -JDE2000W
there are at least two hi temp thermostats (KLIXON) that could be bad. Usually one in the discharge duct, and other somewhere near the heating elements. Also inspect all the wiring terminals near the heater elements.
Jul 21, 2010 | Dryers
Not gettng hot anymore the heating element is not damaged all coils intact dont look bad at all
does it light a little bit or none..... if only a little bit or takes long time then ur vent is restricted check for kinks or if it is pushed back too far or it is clogged , u can check by unpluggin the vent ducting to dryer and run a load if heats then u know for sure ur vent is clogged,,,,,
if no heat at all check the element for continutiy with a meter if it reads anything its okay.... also there is a possibility of 3 thermostats on the back that might be defective or a thermal fuse *** well hope this helps good day
Jan 30, 2010 | Whirlpool Dryers
The dryer is not heating
Look for the air tube that runs from the blower to the drum.
The heating element is normally located inside of it.
I hope this helps
Oct 03, 2009 | Dryers
Dryers will not heat
IF THE DRYER COMES ON AND WILL NOT HEAT THEN THE HEAT ELEMENTS ARE OUT,,LOOK ONLINE FOR DIAGRAM AND CALL YOUR LOCAL APLIANCE PARTS STORE.THEY SELL THE ELEMENT--USUALLY THEY HAVE THE DIAGRAM IN PACKAGE---SIMPLE FIX ,,DONT PAY SERVICE TECH,,I SHOULD KNOW I AM ONE--HA HA
Sep 08, 2009 | Dryers
Dryer run won't heat up took off back panel don't know which tube contain element. if that not the problem don't know where to locate thermal fuse i need pictures diagram illustration
Hi, if this is an electric dryer and is a whirlpool model, the element is located in a housing on the right side (looking at the back)
You can run the dryer and check with voltage meter to see if it is getting 240V. If there is voltage, replace the element. If there is not voltage, check the thermostats and the fuse for continuity. If they do not have continuity, replace them.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Dryer runs no heat
it is probably the element but cut the breaker off then back on then run the dryer again IF IT STILL DONT HEATis then the element or even a limit switch on the element let me know what you find
bill
Jan 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Heating Element
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
Top Dryers Experts
