Question about AT&T Samsung A127 Pay-As-You-Go Cell Phone - Red
My phone keep buzzing charging stopped with the (i) symbol?
Every cell phone I get keeps having a triangle flashing at the top of the screen. anyone know why? im also a victim of gang stalking so I think it is related to that. also, people draw some kind of symbol...
ok what brand of phone. had an odd symbol on one of my phone ages ago and took a bit but i looked up the brands phone symbol online and ha a fix for it pretty quickly
Oct 08, 2017 | Symbol 4 Pdt8046 Bar Code Scanners With...
Uniden model d1364 cordless phone buzzes, sounds like bad connection, when being used, how to stop buzzing sound
Try moving the base unit that the phone cord is plugged into. Keep it away from heavy power users like the microwave and refrigerator. You would also want to keep it away from other transmitters such as your wireless router. Also make sure the base unit is not near your power meter or circuit breaker box. Hope this helps. Good Luck!
Jun 10, 2014 | Lands Phones
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
MY CORDLESS PHONE BATTERY KEEPS DYING
You could try leaving it on charge a bit longer but if it keeps happening it either means dock doesn't charge the battery any longer (check for the charging symbol on the phone when in dock), or the battery in the phone has had its days.
Jun 05, 2012 | Vtech ia5870 Analog Cordless Phone
THE HEADPHONES SYMBOL IS FLASHING AND IT KEEPS BEEPING EACH TIME IT DOES THIS - WHY AND HOW DO I STOP IT - I HAVE TRIED TURNING IT OFF AND ON AND EVEN REMOVED THE BATTERY. GRRR IT DRIVING ME NUTS!
My mom just started having the same problem, not sure if she's getting the earphone symbol or not...and she wouldn't know it if she was but she is getting a beeping noise, I did some research online about the constant beeping and have found only a few answers : - Clean the ports with a q-tip or compressed air, Not to charge by usb cable, Allow the phone to die and give it a full charge. Some people haven't had luck even with master resets so I don't suggest that. If none of these help it's probably a short somewhere.
Jan 14, 2011 | LG Xenon GR500 Cell Phone
My 3G iphone stopped charging anymore,it happened only once i just delayed the charging and the battery indicater displayed full drained.there is battery symbol indicating only red charging level and power...
possible battery problem, i suggest you visit the nearest service center for your phone to be check by a professional.. if it still under warranty much better so you dont have to pay any charge for the repair.
Oct 01, 2010 | Apple iPhone 3G
Buzzing at my cell phone near the flexible
remove the battery... and dont return it so that the buzzing wont come back....
Feb 27, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Can't Charge!!
Try another charger. I broke the plastic that locked into the phone on my car charger and had problems charging. The phone is very finicky about the contacts. Had to replace charger.
May 28, 2007 | Sony Ericsson T610
AT&T Samsung A127 Pay-As-You-Go Cell Phone - Red Logo
78 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
