Question about Sharp Microwave Ovens
Sharp carousel model number R 5A95 serial number 112137 manufactured May 1993. Obtained used without manual. Tried to reheat pizza on high power for 5 minutes results pizza still cold. Tried on cooking a Stoffers family size Chicken pasta. Followed directions 11 minutes on high power with with the plastic cover in place. End result still cold. Took cover off as directed and cooked on 50% power for 18 minutes. Results warm. Since I do not have manual maybe did something wrong or the unit has other problems. If the later is the case will get a new micro wave instead of the cost of repair.
MicrowaveSvc
  • 9047 Answers
SOURCE: Ewave kot-131UB pops breaker
Yes, this is caused by either a bad door switch or a loose door or loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: sylvania microwave
They have that manual their site, but it's only in French!
If you don't speak French, then visit the manual download page and put in only "SM807" in the search box.
The manual for either the SM80703 or SM80704 may be close enough to yours to work.
You will need the free Adobe Reader to view or print it.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 23, 2008
  • 360 Answers
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Posted on Feb 08, 2009
mcdevito75
  • 1970 Answers
SOURCE: emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
Posted on Jun 22, 2010
SOURCE: lost my instruction book.
In a pasta n more the instructions say for thin pasta, water level 4, 17-18 mins.
Posted on Jan 22, 2011
I have lost my operating manual for my sharp carousel sensor microwave oven model R 480B K
Have you tried the manufacturers web site to see if you can download the manual.
May 23, 2016 | Sharp Microwave Ovens
NEED MANUAL4 SHARP CAROUSEL MODELR403KK SERIAL 173160
You can download the owner's manual from my site here at no charge.
May 31, 2012 | Sharp Microwave Ovens
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Dec 27, 2009 | Sharp Microwave Ovens
Sharp microwave suddenly died !
The high voltage transformer that feed the klystron tube usually has a cartridge fuse on its 110 v side.
YOu will have to remove the case to access the electronics... the screw should be obvious...
Note.. you are handy- so the obvious (unplug first) and the even more obvious - keep fingers and metal away from all capacitors in the power supply area.
Oct 22, 2009 | Microwave Ovens
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
I have a sharp carousel microwave(1997}. model#r-220aw serial #120115. i broke the glass carousel plate. where do i find one?
The tray is Sharp part # NTNT-A011WRF0 or NTNT-A034WRE0. (Same part, just different numbers).
Here's the link to where you can find it...
www.microwaveglasstrays.com
Jun 25, 2008 | Sharp Microwave Ovens
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
