Question about Tappan TGF363 Gas Kitchen Range
How do i open/lift top of stove top to install a new igniter?
    Master:
  • 354 Answers
Stove tops side toward you than lift up, if its been a while than it can be a bear
Posted on Apr 08, 2011
The gas range spark igniter does not work. I have a new part. How do I access the range top to replace it?
The whole top of the stove lifts off. You need to pull it out from the wall, unhook the gas, loosen and remove any screws that are on the back that hold the back to the top section. Open the stove doors and look up from the bottom to see if there are screws holding the top down, take those out and lift the top off. You can then access all the parts for the burners.
Oct 31, 2014 | Kitchen Ranges
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
Replacing stove top ignitor
Remove the burner cap and lift the burner the igniter is fitted through the burner and held with a circlip underneath you will probably need to lift the top to access the wiring back to the igniter pack.
May 26, 2014 | DCS Cooktops
GAS COMES ON BUT STOVE WILL NOT IGNITE
check the pilot with the stove off lift the top see it there is a little fire between both burners or you might have a bad igniter
Sep 22, 2012 | Five Star Kitchen Ranges
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Top glass of my mer6770 maytag stove broke from side to side. Part number best site to search and and technique to remove and install the new one. Canadian owner
74006477 main top in black thats assuming you gave the right model number the run about $180
http://www.appliancepartspros.com/Appliance-Parts/MAYTAG-Top-main-(blk)-item-number-AP378228.aspx
UNPLUG THE UNIT
Its an easy replacement open the top oven door look straight up under the top one screw on each side 1/4 inch take them out lift up the front it hooks in the back there are two molex plugs,disconnect those and lift the top off,it's easier if you flip it over onto a table next to the new one and transfer everything from one to the other.
Sep 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I want to know how to get the top of my stove to open
It usually just lifts from the top, some times you may need to engage a lock thing, kinda like when you open the hood on your car.
Feb 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ketchen aid kgst 307
There are several screws under the front lip of top of the range. You will have to open the oven door to see them. Once the screws are removed, the top should just lift up. Of course, if it has been a couple of years, grease and oil can creep into the seams along the sides and cause the top to stick. If this is the case, carefully take a putty knife along the side seams and lift up at the same time on the front. The top should open. Now, if ALL your burners are not lighting, that sounds like a bad spark module. Do you hear a clicking noise when you try to light any of the top burners? If not, the spark module not the igniters, is the likely suspect. The spark module provides a voltage to ALL the igniters simultaneously. Removing the top will not be necessary if this is the case. The spark module is usually located in the back of the oven cavity under bottom pan of the oven. Or, it may be located behind the panel in the rear of the stove. Let me know if this helps you.
Jul 29, 2007 | KitchenAid KGST307 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
515 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Craig Butler
Craig Butler
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
