Question about Dyson DC28 Animal Bagless Upright Vacuum
How to remove the head to get at the motor that drives the brush?
    Master:
  • 354 Answers
I don't know about the Dyson ,but the beater bar (brush) is run by a belt that you can see once you take off the beater bar cover
Posted on Apr 08, 2011
No power in the brush
You may have either excess friction in a bearing or a slipping belt. Unplug the vacuum cleaner, remove the bottom plate, try turning the motor pulley by hand. If it is very hard to turn, remove the belt, then check the brush bearings and the motor bearings to see where the gum-up is. If it turns normally, try turning the motor pulley with one hand while holding the brush with the other to see if there is any slip in the belt or in the brush pulley. If the belt is loose, first check for loose screws or broken motor mounting posts. If those are all good, and the motor is as far back as the screw mounts let it go, the belt is probably stretched and should be replaced.
Jun 25, 2015 | Vacuums
The motorized brush on my DC35 no longer turns. I cleaned the debris from the brush but it still won't turn. The belt is in great shape but the gear is physically hard to turn. How do I fix it?
After removing the screw in the centre of the brush bar drive gear, gently lever the gear away which will reveal a possible build up of hair behind.
Jun 22, 2015 | Dyson DC35 Multi-Floor Cordless Vacuum...
Does the dc24 cleaner head have a drive belt
This might answer your question. Belt can't be seen but there is some drive from the motor to the brush drive.
Dyson DC24 How To Replace The Brush Bar Motor
Support forDC24 Multi Floor
Nov 02, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Brush won't turn bissell vacuum 3760-4
No there is no separate fuse, when you did this you caused the drive motor to overheat, this destroyed the belt as you have seen and likely burned out the motor for the brush head..
Dec 06, 2011 | Bissell Vacuums
How do you replace the belt on xl2200 upright oreck vacuum cleanrer
Ok with the front of the vacuum facing you look on the left had side of the power head then follow these steps.
1.Remove the door by removing
the hold down screw located on
side of power head.
2.Slide the door forward by
prying open with a screwdriver
or coin.
3.Remove the belt from the brush
roll pulley and the motor drive
shaft.
4.Loop the new belt over the
motor drive shaft. Place the
opposite end of the belt on the
brush roll pulley.
5.Rotate the brush roll three (3)
complete revolutions to ensure
that no part of the belt is
overhanging the end of the
motor drive shaft.
6.Replace the door by sliding it
into the groove at the bottom of
the housing. Replace the hold
down screw.
Jun 22, 2011 | Vacuums
The power head for doing rugs has stopped turning.
A clog usually only affects the vacuum action. If the brush is not turning, make sure the motor driving it still runs. Remove the bottom plate and take out the brush assembly--check the end bearings for being bound-up with debris and the brush surface clear of debris. Clean the bearings with a Q-tip, then lightly oil them inside with 3-1 oil or similar light oil. Make sure the brush turns freely when returned to it's place. If ok, install the drive belt paying attention to any necessary twists. Replace the bottom plate and test. If the driving motor doesn't work, try turning the shaft by hand. If bound-up and it isn't caused by wound debris, the motor probably needs to be replaced. Hope this helps!
Apr 09, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Reset blet button will not stay down. what does
Your rest should only be required once if the head stops. If it continues to shut off , you likely have hair or thread wound around the brush in the bearings or a motor which needs to be cleaned and lubricated.Try rolling the brush by hand if it is tight it needs service.
Most of these heads have a headlite housing which pops off to reveal two hidden screws. remove those and look for others near the neck of the head Once removed the housing lid comes off to allow access to the brush. remove the brush but be careful not to lose any spacer washers on the ends, Clean out any hair and thread and invert the belt to inspect if it has teeth , look for cracks or missing teeth. rotate the motor drive with your fingers. it should spin freely . If it is tight or grinds or scratchs you need to have it serviced or replaced. If the shaft feels tight 1 DROP of sewing machine oil or WD 40 on each end of the shaft will help, but clean out any dust first. the reassemble in reverse order.
Sep 16, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Front revoving brushes dont revove
Remove the bottom of the power head(brush unit) and then you should be able to lift the driven side of the brush straight out. The belt is probably broken and this was caused by a build up of hair around the ends of the brush. If the belt is not broken just clear all debris from the brush area and look for a reset button on the brush drive motor. If it does not have one reassemble the unit and it should be good to go.
Sep 07, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC28 Animal Bagless Upright Vacuum Logo
470 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
