Question about Dryers
They dryer wont get hot. the drum still operates but will not heat up to dry. need information on part cost and how to fix.
  • Brian Manuel Apr 08, 2011
    Electric or gas ? if its gas check to see if there is a flame on the pilot Electric is thermostat or heater element Way to check is take element out and check for resistance or just make sure it isn't broke in half if not than its your thermostat. If you don't know what they look like than go to appliance store with model number and he'll have it
  • 413 Answers
You first need to know, is it electric or gas. If it is electric, you more than likely have an electric element burnt out. Most dryers have one element and can be accessed sometimes through a small door in the front of the dryer (depending how old). An "element" is a long coil looking wire that looks like a real long spring. It gets hot and air passes over the element into the dryer. If the element burns out, the dryer will come on, but no heat. You can visible look at the element and sometimes you can tell if its burnt in two. Be sure to unplug the dryer before inspecting.
Posted on Apr 08, 2011
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Our dryer shuts off completely when we dry several loads in a row. It restarts when we allow it to cool down. What is the problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Sep 30, 2014 | Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
Dryer wonT heat, but drum turn
You need a heating element replaced. It is not hard to fix, the heating element should only cost you about $20.00 and for the labor it might cost you $45.00 for the repair man to fix it. A total of about$65.00 maybe even less.
wvrain2006
Sep 29, 2010 | Dryers
Dried a load fine, next load tumbles wont dry. still cant get heat
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Kenmore 63942 Dryer
The dryer drum moves but no heat. Clothes do not
most of the time it is the heating coil their is a
series of springs the heat up and then the blower
sends air pass them and into the dryer to dry the clothes
you will need to remove the back of the dryer
and get to the heating element and look at it
and see it any of the springs are broken
cost for the part 80.00 maybe
good luck
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Dryer not releasing hot air
if its an all electric dryer then you may have an open heating coil or a bad contact on the timer that supplies power to the heating element .. a few dryers have a fuse that could be blown ..
if you have a gas dryer then you may have a bad solonoid that operates the gas valve .. or more likely a bad igniter .. thats a module that heats up or sparks to ignite the gas .. the igniter is a replacable item mounted near the gas flame. . the heated type fail frequently on some dryers ..
Aug 18, 2009 | Dryers
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
