Question about Sony Cyber-shot DSCH55 Digital Camera
Every time I am getting memory card error and system error
  • 122 Answers
Hello, please can you use your camera to format the card? after the formating it will be alright.
Posted on Apr 08, 2011
Record File Error on Guardian 2
I was getting the same trouble with the "record file error" always showing up on my monitor as well, and no recordings were being written into the SD card. I tried different SD cards and the same message was appearing. I was about to pack it up and return it to the store until I did one last thing...and it worked for me! Solution: Using a paper clip, insert the end of it into the "reset" hole under the SD slot and the system will turn off, restart, and voila!...it will start recording again. I hope this helps everyone who has this similar problem out there. I guess the unit just need a good reboot and get some of the bugs out of it's system.
Mar 27, 2014 | Uniden Guardian Wireless Video...
Every Time I Insert My Sd Card It Comes Up Error Volume Label Syntax And I Cant Get My Pictures On To My Computer Wat Can I Do To Get It Working Again??? Please Help Me Straight Away. Thank You xxxx
Some times Memory cards need to be reformated by the operating system you are using, so it will put a volume label when you format it, that way you won't get a syntax error.
When you plug in your memory card when your computer should recognize the Memory card just like a hard disk. That is when you need to re-format the memory card just like a hard disk. then try taking pictures then try transfering to your computer.
Dec 06, 2010 | SanDisk 4GB microSD High Capacity Memory...
Camera memory is full. On upload, indicates no
There could be a memory card error or the Operating system may not recognize the entries on the device. Try connecting the card directly to the computer through a card reader. This might help. If not running a photo recovery software will get back your pictures. Check http://digital-assembly.com/products/adroit-photo-recovery/ and try running it on the memory card. After you get back all your pictures, I would recommend formatting your memory card, so you start off fresh the next time.
Dec 21, 2009 | Kodak EasyShare C330 Digital Camera
Problem with ds fire card error:openx.dat.error
I found something about your error on this previous Fixya solution :
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
Hope it helped.
Nov 24, 2009 | Nintendo DS Lite Console
Valuesoft / arush : Hunting Unlimited 4, I get ''error prism3d".
Valuesoft homepage says:
This error message is stating that you need to update your video card drivers.
Nov 07, 2009 | Video Game Consoles & Games
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
Error openx menu dat error
Mar 30, 2008 | Nintendo DS Lite Console
Stylus 710 Memory card error
try formatting on another fuji/olympus or on a computer, and then again in your camera. this should work no problem. Usually this is just a file system error. In the odd case it is a card or camera error but not likely at all.
Sep 04, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Sony Cyber-shot DSCH55 Digital Camera Logo
79 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
