Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Can't raise temperature
Help! Noticed watermelon and other fruits getting too cold with frozen parts. It is a Bottom freezer type Elite Kenmore. It said 37C so I pressed the button on the front and it went to 36 and then 35 and is now at 41 F instead of C and it is of course much colder!
I want to get it back to at least where it was -- and a few degrees warmer if possible. Now - without your help everything is going to freeze! HELP PLEASE! Loretta
  • 2 more comments
  • soocool5 Aug 06, 2008
    Okay -- so I am to let it remain at the temperture it is at for a day
    and then try again. My question really is that when I pressed the
    button it would only allow it to get colder -- not warmer -- no way it
    seems to go up and down with the temperature. Am I missing something?
    Feeling dumb in Nevada --- Loretta
    Okay -- I'll try it tomorrow!
    IT WORKED! I got it back to 47F rather than the 41F it was at. I just
    kept pressing as YOU said. Now I have to get it to Centigrade and I'll
    be set. THANKS MUCH!!!
    Thanks Ekse-- very much! I have to laugh as I see no Accept button --
  • 13,434 Answers
35-37'Celsius is very warm. room temperature is around 19-23'c idealy
Can you post me the model number so I can get the user manual with the instructions on how to adjust the temperature?
Posted on Aug 06, 2008
  • 4 more comments
  • Ekse Aug 06, 2008
    ok, I think this is close enought.
    http://www.managemyhome.com/mmh/lis_pdf/...
    Refrigerator Temp Control: 33°F to 46°F (0°C to 8°C)
    The lower the number setting, the colder the refrigerator
    compartment will become.
    • Freezer Temp Control: -6°F to 9°F (-21°C to -13°C)
    When the setting is at a lower number, the freezer
    compartment becomes colder. The refrigerator
    compartment becomes warmer because less cold air
    flows into the refrigerator.
    NOTE: If you want to change °F to °C or the reverse,
    press and hold FREEZER key and REFRIGERATOR key
    simultaneously for 5 seconds or more.
  • Ekse Aug 06, 2008
    They have not explained how to adjust the temperature very well, I suppose it is very simple.
    Try pressing either freezer temp or refigenerator temp and the temeperature should go up or down, when it goes high enought it should either turn back or start over.
  • Ekse Aug 06, 2008
    see my latest comments on this page
    http://www.fixya.com/support/t890005-mod...
    also I sent you a link to the user manual, so you can print it out if you wish.
  • Ekse Aug 06, 2008
    you can try it today, just get it to the correct setting and then wait 24hours for it to adjust.
  • Ekse Aug 06, 2008
    Great! please press on the accept button as we solved the problem! :-) Let me know if you need anything else later, you can use the ask me button.
  • Ekse Aug 06, 2008
    the C to F changes is covered in the manual same page by the way if you printed it.
SOURCE:
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ...
www.dslreports.com > ... > Home Improvement
DSLReports
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Jan 03, 2016 | Whirlpool W8RXNGMBD Universal Silver 17.6...
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bottom drawer of the refrigerator freezes the fruit.
I think the thermostat is faulty. Thus it makes the freezer extra cold. Try replacing it. Regards, Nandini.
Sep 07, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 795
check the damper controller at the center of the fridge. this regulates the air that is coming from the freezer dependent on the signal from the thermistor of the fridge compartment. that is the other thing to check. check it for rresistance and it should change as you change the temperature of the sensor.
i hope i was able to help;;
May 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
112 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
