Question about Kenmore Dryers
Dryer only works if the start button is held down
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 08, 2011
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
May 24, 2009 | Dryers
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
Dryer won't run except when start button is held
you need a new start button and switch
Jan 12, 2009 | Kenmore Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Dryers Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
