Question about Cameras
Samsung L850 lens is stucked and camera is on
  • ttrucho Apr 12, 2011
    Thank you very much!!!! You saved my camera, I tried fix #1 & # 2 or a combination of both. The good thing the camera is working right now. Thank you again,
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 08, 2011
Lens stuck
Please see this link for troubleshooting steps for a stuck lens.
And here's a video summary of the steps.
Apr 28, 2013 | Samsung S860 Digital Camera
Samsung x860 digital camera lens stuck
Time for serious repairs or a new camera.
Nov 28, 2012 | Samsung S860 Digital Camera
SAMSUNG L301 CAMERA LENS STUCK OUT
my camera samsung L301 lens stuck when swicting on
Feb 04, 2011 | Cameras
Basically, the lens is stuck out of my Samsung P12...
the lens stuck out of my Samsung SL420.
May 20, 2010 | Cameras
My SAMSUNG TL100 CAMERA LENS STUCK OUT SIDE
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
or
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Mar 04, 2010 | Samsung TL100 Digital Camera
My lens seems to be stuck
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Jul 10, 2009 | Samsung L200 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Camera Lens Stuck Closed
I am having the same problem. Were you ever able to resolve yours? Thanks!
May 02, 2009 | Samsung L200 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
