Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens three times without me pressing anything and the tv still doesnt turn on, what do i need to fix this?
  • 10,594 Answers
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Posted on Apr 08, 2011
  • evilpea Jun 04, 2011
    If what pins are shorted?
  • Shahid Electronics
    Shahid Electronics Jun 04, 2011
    Collector and Emitter pins usually shorted.
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Got tv from friend want come on
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52in rca hdtv
Hello lindseyskirk,
This is a common problem with this TV set as it uses the ITC222 chassis. The problem is usually localized to a group of capacitors
CP120, CP140, and CP150. If you have a background in electronics I can send you the schematics and you can unsolder them and replace them using the schematic to get the values from. If you do not have a background in electronics, I would suggest you have a qualified Television Technician do the replacement for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I HAVE A RCA 52IN TV IT WANT COME ON. THE POWER BUTTON TURNS ON AND OFF THREE TIMES BUT NEVER POWERS ON
sounds like the flyback as thats the 3 error code, but to be positive please respond to this same post with the model number of your RCA, and I will be able to help you out with your problem.
Jul 05, 2008 | Televison & Video
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Screen dont work
proabably it,s because you left it on for long time , or the image power saver is wrecked and damaged after a storng lightinning , and if you have cleaned ther tv screen with a wet wiper it causes that to happen
May 11, 2008 | RCA P52937 52" Rear Projection Television
Need a Power Supply / Deflection Board for a RCA D52W20BYX1 TV
Check HERE and provide the vendor with the chassis number as well.
The model number helps but the chassis number is very important.
Good Luck.
Mar 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
297 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
