Question about Goldwell Topchic Effects Highlight Color 2 + 1 Tube ReNew Mix
What is the formula for goldwell renew mix. And what's it for
Hi...I recently used Goldwell topchic 9N and mixed it equal parts with topchic 30 vol. cream developer. My roots came out a reddish tone which I do not like. My virgin color is between a 2 and a 3 (Dark...
it's only possible to lift 3 shades (like 3to 6, or 4 to 7) without taking undertones into consideration. To go from a dark brown (level 3) to a 9n you would have to pre-lighten your hair with an on the scalp bleach first. Then color with 9n and 20 volume
Jan 27, 2015 | Goldwell Health & Beauty
Colored hair a level 10 and got ashy tone now want to either lowlight or go to a level 8 or 9 Would like to use goldwell Demi acid
an 8 would do nicely I think. And demi is right on the mark there! I have never used goldwell but that is what I trained with and it is a wonderful color line. good luck!
Aug 23, 2013 | Health & Beauty
Topchic 12bs did not color hair
Try 2 0z of 40 volume goldwell developer to 1 oz 12bs topchic color. process at least 45 min
Jan 13, 2013 | Goldwell Topchic Hair Coloration 2 1 Tube...
I'm using Goldwell 12BG which says 2+1 on the box. Is the formula 2 oz. of developer/peroxide to1 oz. of toner or is it 2 oz. of toner to 1 oz. of developer/peroxide and should I use 20% or 30%...
Ratio is always developer to color, so a 2:1 is 2 parts developer to 1 part color. Example mixture is 40 ml developer to 20 ml color.
30 vol gives you better control and less damage to your hair. If you have VERY dark hair (level 5/4 or below), you need to pre-lift and then apply the color. It sounds like you're not a trained stylist, so I don't recommend 40 vol as it lifts too fast for most people to get an even application, especially if you're applying it to your own head (since it takes longer to do generally speaking).
You can work in sections to preserve color and get a more even application. Simply mix enough color for one section at at time, apply and process, then rinse ONLY that section with water to stop the chemical process. Repeat on all other sections. Good luck!
Mar 27, 2011 | Goldwell Topchic Effects Highlight Color 2...
I have the Bissell heat pro 2x 8920 and the water doesn't come out. The soap just mixes with water tank and the carpet stays dry
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Jun 14, 2010 | Bissell 8920 ProHeat 2XTM Upright Vacuum
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
I lost the owner's manual. I don't know how much
Located on the back side of the plastic container in which the formula and water is mixed into has an indicator for the formula and a separate indicator for the water. You should be able to obtain a copy of the manual from the Bissell website.
Jun 30, 2009 | Bissell 1425 Little Green ProHeat Handheld...
I purchased a Pro Heat self propelled Bissell rug cleaner model 7950 from Target wherehouse on 4-26-06. I used it once and all was fine. The next time that I went to use it the smart mix for the cleaning...
I assume that it is spraying water? Is the smart mix knob turning freely from one point to the end? If not then there is a problem with the smart mix asm. With liquid in the soap bottle, push the valve in to see if liquid comes out ok, couild be that the valve is bad. Is the seal on the valve at the bottom of the bottle, it has to be on that and not just sitting in the hole. You might try running a mix of water and vinegar thru it, maybe it is clogged up.
Apr 14, 2008 | Vacuums
Excel formula
Relative cell reference is address of cell , when copied from one cell to another gets changed automatically.
e.g. Put formula in cell c5 as A5+1 when you copy this from c5 to c6 the address of A5 will automatically changed to A6.
Absolute Cell Reference
As above now put formula in cell C5 as $A$5+1 ,now copy this formula from C5 to C6 if you this formula youwill find cell Address of A5 does not changed.
Mixed Cell Reference:
If we put Dollar ($) sign before Alphabetic cell address i.e.$c5 then even if you copy this formula in any cell , coloumn (c)  will remains constant.
Similarly if we put Dollar ($) sign before Numeric cell address i.e.c$5  then you copy this formula in any cell row address of the cell remains same.(5).
Pl elobarate on remaining two points 'Specific order of formulas ' and 'advance formulas,
Sep 15, 2007 | Microsoft Office Standard for PC
Goldwell Topchic Effects Highlight Color 2 + 1 Tube ReNew Mix Logo
117 people viewed this question
Top Goldwell Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Goldwell Health and Beauty Expert? Answer questions, earn points and help others
