Question about US Acoustics USX-4065 Car Audio Amplifier
I have 4 infinity kappa speakers running off this amp. Can u give me the best settings for this amp.(from left to right) #1 - low pass between 40-200 ? #2-(for channels 3+4) level,mode, & highpass. Then repeat 3 settings for channels 1+2. Then selector in 3+4, 1+2, or low. The 2 rca plugs for back go in Line Out L & R, Inputs 3+4, or Inputs 1+2 ?This amp was hooked up and got unpluged and changed and need correct settings for 4-channel use again.
I have a kicker zx350.4 for door speakers and the amp keeps cutting off once the bass hits hard or i have it aloud , once i put the volume down or bass low it comes back to normal and amp doesnt get hot at...
kappas are 2ohm. You are running that amp at 2ohms stereo on front and rear channels. That is a nice amp, but it is a thirsty one. If you have a sub amp as well, then you are not supplying your amps with enough power. drop down to 0 gauge and see if it heats up anymore. Also, try going high pass if you have subs. If you don't have subs. You need to run 4 gauge and make sure you have a great ground.
Oct 31, 2014 | Car Audio & Video
I have a 2002 Chevrolet Camaro with the Monsoon stereo system, The front speakers take four wires. The Infinity Kappa 62.7i were the perfect speaker, but they stopped making them. I do not want to put...
one of those wires on your speakers is the common ground for both sets of wires in your camaro, Just take the negative wire from both sets of wires and run it to the single wire on your new speakers. The other 2 are positive from each wire. good luck
May 24, 2010 | Infinity KAPPA 62.9I Car Component System
I have a 500/1 Slash series amplifier hooked up to a pair of 12" infinity Kappa perfects. I have a factory dash unit still in a 2007 Lincoln MKZ so im using the converter that converts the speaker wire to...
What may of happened if that you got the lacquer finish on the electromagnetic wire to heat up and come apart. At low volume they will still have an electric connection. Because the wire physically came off from the inner housing of the voice coil it is in contact with the side wall of the speaker magnet and is proned to causing a short between coil sets. Your probably running subs with a 4 ohm impedance and when your coils short it acts more like a 2 or 1 ohm speaker. This is similar to whats called a dead short. Since the Independence is dropped to 2 or 1 ohm it is the resistance equivalent of having 2 or 4 subs attached to your amplifier which caused the final transistor bridge to heat up and it can get hot almost instantly. Check your amps outputs individually on a single speaker that you know works perfectly. If your amp does not trip the thermal protection you most likely cooked a speaker beyond usable condition.
May 24, 2010 | Jl Audio 500/1 Car Audio Amplifier
How do i get the best sound from my infinity 1250w subwoofers
Make sure the ohm's are the same on all your speakers and amp.
You amp watt should be equal or higher then your speakers total amps.
You base box should be completely air tight, and have about 1/2 of the box stuffed with cotton.
Make sure you use a good thick speaker cables to connect from the amp to the speakers.
and finally, make sure your trunk seals tight and wont rattle... cause nothing sounds worse then someone pulling next to you and all you hear is a buzzing sound from the trunk rattling... Also... sell the infinity's and get something like memphis, or panasonics. :P
Mar 09, 2010 | Infinity 1250w Car Subwoofer
I have 2 infinity kappa speakers in the rear deck of my car. i had a stereo system in the trunk but it didnt really do much except throw more bass in with the music even then it wasnt that much bass. i...
You sold the subs, or sold the infinity kappas? After selling a sub system it is often more than disapointing to go back. It often does sound quiet. You can either deal with it for a couple months until you get used to it, or I'd go with a set of MB Quart to replace your kappas.
Oct 08, 2009 | Infinity KAPPA692.9I Coaxial Car Speaker
Vibration in midrange speaker - Infinity Kappa Series home speake
I have what sounds like the same problem with my Infinity's. Found a small crack in the foam surrounds of the speaker cone. Looking for a place to buy rebuild kits on the internet when I found this. Hope this helps.
Mar 18, 2009 | Audio Players & Recorders
2 sets of pos. and negs. on 10" infinity reference 1052w
This means you have a dual voice coil sub. It is probably a dual 4 ohm voice coil. If you hook up the left channel to one input and the right to the other you can safely push the sub but the amp will be running at a lower efficency. In other words it isn't the best amp for the job because it can't push max power to a dual voice coil speaker but it will work.
Jan 30, 2009 | Infinity 1250w Car Subwoofer
How to install infinity kappa 63.5i speaker with an amp
If you can give me more info should be able to help ,what rms wattage is the amp and speaker is it a subwoofer or pair of speakers.
Apr 19, 2008 | Car Audio & Video
Car stereo crossovers
you should be able to remove the passive in-line crossover, but since it is blocking everything below 3500 hz, there is no need. leaving the passive crossover in place will also help protect the tweeters if something fails in your setup as any amped frequency below 3500 can seriously damage them.
Nov 11, 2007 | Infinity Kappa 10.7t 1'' M.M.D. Dome...
US Acoustics USX-4065 Car Audio Amplifier Logo
44 people viewed this question
Top US Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you an US Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
