Question about Kenmore 63932 Electric Dryer
The unit only works if the start button is held down
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 08, 2011
Maytag refrigerator MFI2568AES. "Change Filter" light will not turn off. Held down filter reset for 3 seconds - did not work. Held down the light and lock buttons for 3 seconds - did not work. Wha
Hello Don;
My name is Peter. I am a retired field service refrigeration technician.
Your filter reset is just a independent timer set for six months. It is not tied into your water filter. You should change your water filter when your water dispenser flow is slow and/or you start to get small ice cubes. Depending on the usage, your water filter can last 18-24 months or more.
Unplug your unit for about 10 minutes to let the unit power down, then plug it back in.
Dec 31, 2014 | Maytag Refrigerators
Unit won't shut off
Swithch yhe on/off button to left, mean off position and held it gor about three second. The unit will now shut down
Mar 12, 2014 | Garmin Nuvi 1490T
Fisher & Paykell Nemo model 820 won't start
It sounds like the interlock switch on the unit isn't working, it is a switch than closes when you lock the unit to start the wash cycle. there may be something interfering with it. look to make sure you have a good seal when you lock the unit if not then something is blocking it from sealing properly this will make the buttons give a beeping sound and not work. Hoe this helps.
Nov 18, 2013 | Dishwashers
I have a Rheem Classic X ac unit ive checked the breaker, reset it, checked the furnace, changed the fuses, but it still will not turn on unless the button on the contactor is held down manually, when held...
Most Rheem units have a manual high pressure safety switch accessible from outside the unit. It has a little red rubber boot over the button thats about the size of a pencil eraser. Its located near the bottom where the refrigeration lines are connect to the unit. Make sure the wire is connected to the y terminal at the thermostat. Wish I knew your expertise the next step would be to jumper the r terminal with the y terminal at the thermostat and if the unit comes on you know the thermostat has failed hope this helps and good luck.
Aug 17, 2013 | Heating & Cooling
Disgo 7000 frozen at start up
Evening Mark,
You can do a recovery mode boot on these by holding the Home (H) and Back (Button on front) Buttons then switching on when asked to press correct keys briefly release the home key and then repress this will then start the recovery mode.
Mar 04, 2012 | Photography
The beeper on my HP Officejet 6210 All-in-one unit is on all the time on or off with power button. The only time the beeper stops is when it is unplugged from the wall outlet. I got an auto reply to try to...
I want you to try NVM (Non Volatile Memory) reset for this printer. Perform the printer is connected directly to wall outlet with now Surge protectors.
Steps:
  1. Remove the ink cartridges.
  2. Disconnect the power cable from back of the printer while its ON.
  3. Press and Hold OK and CANCEL button, while holding the button insert the power cable and continue holding it for 20 seconds
  4. Printer will turn OFF.
  5. Turn ON the printer and insert cartridge when it prompts.
Regards,
Rizwan.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Delete or reset a wrong firmware file for IVO- m600 mp3 Player (Rockchip)
This is how to get into update mode,
All you do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the "MENU" or the "PLAY" button and keep it held down.(try the other buttons if these dont work)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the button.
5) You should be now in "ROCK USB" upgrade mode
6) Then just start ConsumerUpdate and upload your firmware.
Nov 18, 2007 | Audio Players & Recorders
Kenmore 63932 Electric Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
