Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
F-05 on panel - Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • 17,970 Answers
F-05 Error Message
The fault is associated with drain out (pump blocked or restricted in some way),
pressure switch is jammed on empty or a problem with pump.
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Keep us updated about your tests.
Posted on Apr 08, 2011
Tip
How To Install Remove Rear Door Panel 1st Design Buick LeSabre 00-05 1AAuto.com
on May 03, 2012 | 2002 Buick LeSabre
Tip
How To Remove Door Panel 1st Design Buick Lesabre 2000-05 1AAuto.com
on May 02, 2012 | 2000 Buick LeSabre
IS GM tech2 available on my Cadillac year 1996?
GM Tech 2 support for on-board diagnostics on all GM systems 1992 thru 2011.The following GM vehicles utilize the CAN interface:
05 Buick Allure (3.6L)
05 Buick LaCrosse (3.6L)
05 Buick Rainier (5.3L)
04-05 Buick Rendezvous (3.6L)
04-05 Cadillac CTS (3.6L)
04-05 Cadillac SRX (3.6L / 4.6L)
04-05 Cadillac XLR (4.6L)
05 Cadillac STS (3.6L / 4.6L)
05 Chevrolet Cobalt (2.2L)
05 Chevrolet Corvette (6.0L)
05 Chevrolet Equinox (3.4L)
05 Chevrolet TrailBlazer (5.3L)
05 Chevrolet SSR (6.0L)
04 Chevrolet Malibu (Body/Chassis only)
05 Chevrolet Malibu (3.5L)
05 GMC Envoy (5.3L)
05 Pontiac G6 (3.5L)
05 Pontiac GTO (6.0L)
05 Pontiac Pursuit (2.2L)
Jul 03, 2013 | Cars & Trucks
My Precor EFX 546i control display panel would not work. i.e, no resistance control, no level control, the panel would not hold a charge when I started to pedal. the battery was then replaced but the only...
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 19, 2013 | Precor EFX 546i Elliptical Version 4
Need a code for my philips to reprogramme my sky remote my model is 28pt4458/05
Try these codes.
0081
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
Apr 19, 2012 | Philips Televison & Video
Can I get the user handbook for model no 19PFL5522D/05 e mailed to me free of charge?
sure, click this link to download
http://www.nodevice.com/user_manual/philips/tv1/19pfl5522d05.html
enter the image verification to the buttom, click download select a server and download your manual.
Apr 04, 2011 | Philips 19PFL5522D/05 widescreen HD ready...
How do you take off a rear door panel 05 chev pu
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
Oct 14, 2009 | 2000 Chevrolet 3500
F-05 flashes up and water not draining out
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Jun 30, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
133 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
