Question about M-Audio BX5a Speaker
Sounds as if the woofer is blown. seems t be a vibrating noise. this will be the third time fixing this problem.
    Problem Solver:
  • 7 Answers
Have you taken the unit apart and checked the filter caps? they are 2 big black 25v 6800 uf capacitors and they commonly go bad on these studio monitors. look and see if the tops of the caps are bulging up, if so, replacing them would fix your problem (considering your not just cranking it too loud either! )
replace with anything bigger than 25v ! common replacements are 6800 uf 35v and 6800 uf 50v . obviously have a professional preform this repair if your not comfortable with a soldering iron.
Posted on Dec 08, 2012
  • 24 Answers
Get some higher rated speakers as this will happen time after time, or you could turn the bass down lol
Posted on Apr 09, 2011
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
One of my speakers has started emitting a " fartinf like sound, it's not blown but sounds like someting vibrating against the woofer, if that makes sense?
Check to make sure all screws are tight. If they are, it's possible the surround or the spider on a woofer is letting go. Check to see that they are intact.
Jan 20, 2011 | Alesis M1-Active MkII Main / Stereo...
The sub seems to go on and off during diffferent movie scenes or tv shows. Is this typical? How do I fix it
Well first yes this is normal for the subwoofer to not always be pounding bass. There are times when there is no bass or it is all treble. If you are watching tv and say a action scene is happening and it goes in and out then Its most likely a either the amp that is powering the woofer is blow or the woofer is blown. Also it could be loost connections inside the woofer. But that doesnt sound to be the case as youd have to wiggle/jiggle the cables to get them to go back in play. Thanks, MIDwest-tek
Aug 31, 2010 | Yamaha Rx-v565 Receiver
Static noise in Yamaha HS50 monitor
Sounds like the voice coil is damaged on the woofer. If you GENTLY press in on the woofer cone, and release, you should not hear any scratching noise. If you hear noise, the woofer needs replacement.
Aug 18, 2009 | Yamaha HS50M Main / Stereo Speaker
Speakers work fine. But left earpiece has low vibration.
I had exactly the same problem. They will give you a new pair for $100, even if it has been longer than a year... Here is a link to my blog post...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Mar 29, 2009 | Bose QuietComfort 3 Acoustic Noise...
My QC2 right headphone starts to buzz, like a vibrating sound
It is a blown woofer in the headphones that is causing the vibrating. Because when a woofer is blown is will develop a small tear, this tear will get bigger over time and cause that "vibrating" sound that you hear. Lucky for you joenfrancis your headphones are still under warranty so they will replace the headphones for free. Hope this helped!
Feb 20, 2009 | Bose QuietComfort 2 Consumer Headphones
Car audio sub woofers
is it the car vibrating or the sub making the noise ? if its the sub making the noise check all the screws holding in the sub and make sure they are tight or make sure nothing got sucked into your box if it is the car making the noise try using dyna mat to help stop the noise also check the surround on the sub and make sure there is no seperation of the surround from the cone
Aug 12, 2008 | Car Audio & Video
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
M-Audio BX5a Speaker Logo
386 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
