Why will my printer not print a job but if I restart my computer it will print?
  • 113 Answers
FIRST I WANNA KNOW WHETHER IT IS INSTALLED OVER THE NETWORK OR NOT. IF YES CONFORM WHETHER WHETHER IP ADDRESS IS STATIC OR AUTO. IF IT IS INSTALLED IN AUTO IP MODE REGISTER THE IP ADDRESS IN THE DHCP SERVER.OTHRWISE INSTALL THE PRINTER USING STATIC IP.
Posted on Apr 09, 2011
Print job frozen on Brother MFC-6490CW
Power down your printer to clear the cache and re load from page 3.
Jun 20, 2017 | Brother MFC 6490CW InkJet Printer
Will not print anything
Hello.
If there are no jobs in the queue, be certain that your USB cable is snug.
If still a problem and there are jobs in the print queue, go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. Install the printer driver.
If still a problem, let us know if any error messages and please provide more details.
Hope that helps.
Dec 15, 2009 | Samsung CLP 315 Laser Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HP 7680 is "mirror" printing. Latest driver has been downloaded again. Mirror printing feature is "off,"but it's still mirror printing. Anyone have a solution??
Open Printer jobs and delete any print jobs pending. Restart Computer.
Otherwise, uninstall all printer software, disconnect printer, restart pc. resinstall software
Apr 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 1020 LaserJet Problem I can only print one job and then have to restart the computer before it will print again. The jobs are in the print que, they just won't print. When I restart the computer a...
Change the USB cable. The cable you are using isn't sending data BACK to the computer that tells the computer that the printer is ready, and you have to reset, Change the USB cable for a NEW one, and then your computer will talk to your printer and vice-versa.
Feb 16, 2009 | HP LaserJet 1020 Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
48 people viewed this question
k24674
jasbo
jasbo
