Question about LG Washing Machines
A hot smell when opening the door after cycle is done & clother also smell like burnt rubber. Also the tub is wobbly when you turn it by hand with the washer empty. There was a piece of grey rubber in with the clothes after the last load. It looks like a piece of rubber is missing from the grey seal on the door opening.
  • LG Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem can be a loose/worn out belt or the door seal that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Apr 08, 2011
Burnt rubber smell during spin cycle
Assuming it's a top loader, the coupling between the motor and the tub is failing. If this is an older machine, the cost of replacement may not be within reason. The cabinet has to be removed and additional disassembly is required to replace the coupling
May 15, 2013 | Roper RTW4300SQ Top Load Washer
My Wash smells musty
In most Owner's Guides for front load machines, manufacturer's will advise to keep the door open after almost every cycle to help evaporate the water in the unit. Also to clean the rubber door seal with bleach water. To get rid of the smell there are solutions on the market that you can throw into the tub when you are not washing clothes and run a hot cycle. You can also use bleach, white vinegar and lime juice as an alternative. Then run a hot cycle. Do this about every 2 weeks, and keep your door cracked.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
My bleach container does not empty at all also my cloths don't seem to be getting very clean and my towels have a weird odor to them after being used for just one time. I get the cloths out of the washer...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((%%&&
Sep 18, 2010 | LG WD-16115FD Front Load Washer
Hi,I have the first year model Neptune washer.So it's about twelve years old.It's not spinning out regular sized loads of laundry.And now I can smell a burning odor when the last load got done.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&^
Aug 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Horrible odor from Frigidaire Affinity ATF6700FS
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%&
Sep 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Not cleaning low pressure smells hot looks like
Sounds like the dishwasher is not getting enough water during it's fill cycle due to low water pressure on supply line or the dishwasher pump is not working correctly. Could be obstructed with food matter, etc.Hope this helps
Jul 30, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Musty smell from rubber seal
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
