Question about Car Audio & Video
I have a Kenwood KVT514 system. I want to connect my ipod touch to the system and have purchased the needed connector. I have connected the usb, audio and video inputs, but for some reason the plug-in into my ipod causes the ipod to continuously beep like it is connecting and disconnecting constantly. Is it the chord or have I not installed it properly?
  • 11,800 Answers
The only thing you should connect is the cable adaptor - KCA-IP301V - so remove the headphones cable and make sure the data cable is firmly plugged in. Also make sure the latest firmware is installed. Finally connect the IPod when it unpowered and find out if it recognizes that its connected when you power it on.
If you get the same result then the data cable is defective, replace it.
Posted on Apr 08, 2011
I just bought a Kenwood KDC-MP439 and the box says made for ipod........ But i dunno how to use the feature...... Help!!!!!
This particular model is advertised as being "made for iPod," but this claim is a bit misleading. Most decks advertised this way mean "iPod ready," but require you to purchase an additional accessory to use that functionality.
In the case of the KDC-MP439, you can use your iPod with the deck by connecting the iPod to the AUX connection on the right side of the faceplate. Making this connection will require you to purchase a cord with 3.5mm male audio connectors on both ends (it's the same connector on your headphones that plugs into the iPod's headphone jack, only you'll need one with that connector on both ends of the cord).
If you'd like to take advantage of the wireless Bluetooth functionality of the iPod, you will need an iPod Touch (2G, 3G, or 4G versions) and the Kenwood accessory KCA-BT100. This component adds hands-free Bluetooth functionality to your stereo. You can find this module at many locations in a range of prices. For example, eBay has them for prices as low as $39.99 (may be a minimum bid for an auction-type listing; be sure to check the listing type if you go this route). Online retailers seem to vary between $99.99 and $150 or so. These will include a manual that should provide instructions for pairing your iPod with the stereo unit.
If you find this information helpful, please remember to give this solution a positive rating!
Jun 14, 2011 | Car Audio & Video
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
How do I hook up my parking brake to my kenwood kvt514
To be able to watch video while the car is in motion or the parking break is released just ground it or connect it to the ground wire (black) and then ground the pair.
I have the Kenwood DDX-512 and that worked great for me!
May 05, 2011 | Kenwood Car Audio & Video
How to conect ipod to the pc
The iPod comes with a cable with a wide-connector at the end that connects to the iPod, and a standard USB-connector at the other end, that connects into any USB port on your computer.
Download: http://www.Apple.com/iTunes the free iTunes software, install it, and use it to copy music from your computer to the iPod, and to purchase music from the iTunes Online Store.
Feb 01, 2011 | Apple iPod touch
Kenwood KVT 514 in dash radio. Ipod classic is connected through the usb cable. Ipod is playing and showing onscreen progress, however, there is no audio coming out of speakers. Have been unable to make...
you need to purchase the ipod cable... your ipod is connected through the usb cable which does not provide sound to the unit but everything else works
Aug 15, 2010 | Kenwood KVT-514 Car DVD Player
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
Ipod touch cannot connect
Try a different usb lead or port might be it's faulty. Did your friend have the same issues ever?
Jan 18, 2009 | Apple iPod touch
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
