Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
I can start my engine but imediately shuts off. i checked the fuel filter but didnt seem to be clogged. Maybe the fuel pump? if so could you send a pic or description of it and its location
  • 126 Answers
Something else u can check is the oil these engines have senors for the oil, if it gets low it will not crank or stay running
Posted on Apr 08, 2011
    President:
  • Poulan Master
  • 1,545 Answers
Make sure that the brass bolt (main jet) that is actuated by the solenoid on the bottom of the carburetor bowl is clean and clear. Shut off or drain the gas. Unplug the wire terminal plug on the solenoid. Unscrew the solenoid from the float bowl and examine carefully. All holes should be clear and the jet should be nice, clean and shiny. Use no metal objects on it to clean it.
Engine quit running while driving & will not restart.No noise or sputtering.Full fuel tank.
recheck filter is in correctly ---also check for fuel pressure pump may hum but it also has a filter in tank [protects pump]that may be clogged --carboned up egr valve will cause stall with no start as well as clogged cat converter ,
Jul 25, 2015 | 1993 GMC G2500
Vehicle starts runs for 1-2 minutes then quits, Starts right up. Fuel is being shut down.
Also what no one is mentioning is to make sure you have oil pressure, or that the oil pressure sensor is working, alot of newer vehicles run the fuel pumps off of them oil pressure sensor so if your vehicle stops pumping oil and lubricating, it shuts the fuel pump off to protect itself from damage or further damage
Apr 08, 2015 | 1993 Lexus Es 300
Fueling up. If vehicle is running engine will idle rough and shut down. If engine is off, it fires up when you start it, and then quickly seems to run out of fuel and shuts off. when you attemt to restart,...
Clogged fuel filter or bad fuel pump. Check fuel pressure before and after filter. Could also be a mass air flow sensor going bad or a air leak in the intake manifold.
Feb 13, 2014 | 2000 Toyota ECHO
1977 Porsche 924 New fuel pump and filter no gas just air.
I would check the fuel lines where they attach to the sending unit. The rubber inside of the nylon weave is probably rotten and sucking air instead of pulling the fuel up and out of the tank.
Apr 23, 2013 | Porsche Cars & Trucks
I have 2002 audi a4. does not start. engine cranks but seems like there is no power going to the fuel pump, when bypassed the relay and directed the fuel pmup it does run but car still did not start......
Check inlet hose from tank for leaks , check for obstruction , or collapsed hose check tank pickup . Try pressure testing pump output for proper pressure check injectors ....
Jun 11, 2017 | Audi Cars & Trucks
No gas going into the injectors or motor. i have spark and fuel pump is work vey good. pulled two spark plugs and smelled it and no scent of gas. thank you and God bless you
i didnt see any mention of fuel filter, maybe totally clogged, if pump is running and you can disconnect the line going from the filter to engine and have key turned on see if gas is coming through there.. maybe pump running but not pumping i have seen it before..
Dec 10, 2010 | 1992 Nissan Maxima
My 2000 ford contour wont start. Engine cranks, but seems no spark. I checked plugs and coil. Fuel pump kicks on and shuts off after primed. It just got harder and harder to start, finally it wont start.
Have you changed the fuel filter.
Your pump may be priming but the pressure could be against a clogged filter.
You might want to check the fuel pressur at the rail.
It might be a fuel pressure regulator problem
Oct 13, 2010 | 2000 Ford Contour
Fuel pump makes a stuck up noise, or maybe the fuel filter
|Hi there.
Niall In General Auto repair in Ireland here.
Maybe the fuel pump has broken and needs to be replaced.
Take it out and bench test it if it works remove the fuel filter and turn the ignition on but not the engine and see if fuel is being pumped up maybe it is only a blockage .
I Hope this helps.
nialljkeogh@generalautorepair.ie
Apr 11, 2009 | 1991 Chrysler LeBaron
When i start the car it idles ruff and dies sometimes the check engine light is on. It dies while trying to drive when you let off the throttle.
My friend, you seem to have fuel problems. the honda have an electric fuel pump inside the gas tank. it maybe old and does not develop enough fuel to the injectors that explains why it conks out.
first replace the fuel filter, it maybe clogged that fuel cannot flow anymore. if it still conks.
check the fuel pressure at the fuel filter it should develop 32psi or more. otherwise, replace the fuel pump.
the worse is that your injectors are contaminated with FOD, you have to replace the 4 injectors.
Jul 29, 2008 | 1996 Honda Civic
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
