Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
It starting to put out a hot type smell. I have tried cleaning the filters real well and even tried to see if there was problem with the ozone filter. We have checked and could not find a jam. I know the hose has excellent suction. The vacumn works but the intelliclean sensors will not. It only takes about 15 seconds or so for the odor to start. Then it gets real strong and it makes my eyes water
  • 710 Answers
The hot smell could be from the belt or the motor. Turn it on for a moment, turn it off, then flip it on its side and smell the belt that drives the brush. If that is where the smell is coming from, then your belt is burning up.
FirsYou'll have to replace it. Be sure there is nothing rubbing on it like debris picked up and stuck. But, even if you do find something stuck in it, you'll still have to replace it since it's burning.
If the smell comes from the motor, do not run it anymore. That will have to be serviced.
Can you get a belt? I can look up a place online for you if you need to order one. Just provide your make and model.
I hope this works. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 08, 2011
Testimonial: "I will check that out. Thank you for the quick response."
My vacuum smells all the time like someone threw up. It stinks the whole house. It is not a burning rubber smell as the smell is there even if not using the power head.
Have u got dogs? if its smelling bad "we are what we eat" and so is the vacumn.try a carpet powder "shake and vac etc." Empty after each use
Apr 07, 2017 | Vacuums
Smells hot when running and will not pick up debris I recently cleaned all filters
Something is stuck in the piping system. The passing vacuum air is used to cool the motor. It's not getting that air so it will start to over heat and smell
Jan 09, 2014 | Eureka Surfacemax 200 Bagless Upright...
I'm getting a horrible sour/sweaty like smell blowing out of my Henry when vacuuming, i've tried to clean the filter, but its still just the same & the smell also seems to be in the head o
You can buy little sachets of nice smelly stuff to put inside Henry. Most supermarkets have them. Makes the carpets smell nice too.
Feb 07, 2013 | Henry Vacuums
Can you wash canister and vortex assembly in Dyson DC17
you need a Hyla they use water as a filter and the smell goes down the drain
Jan 22, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc18 smells like dirty dog
I would clean the filter and let it dry completely for 24 hours. if you put the filter in wet and the run the vacuum the moisture well go in to the cyclone and the dirt would attach to it causing a snowball effect if you will, causing the vacuum to build up with debris and to smell. so clean out that filter really well and let it dry really well then try it out. if it still smells then i would replace the cyclone. they run anywhere around $80.
Jul 17, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I was vacuuming with bissell 3750-T and I shut it off and went to turn it back on and will not start or do anything, what is wrong?
If you can't smell burning then it's probably a broken power switch or the vacuum got too hot and the thermal overload protection has tripped. Try leaving it off for 15-30 minutes and try it again. The thermal overload will reset itself during this time and it should work again.
In the meantime, make sure you have power to the vacuum, check for any blockages and check that the rollers in the cleaning head will turn by hand. Also, give your filters a clean. Any of these could cause the vacuum to overheat.
If you've already done this and/or power doesn't return after 15-30 minutes, I would start by checking the switch.
A couple of questions . . .
1. Does the power switch feel "normal" - basically does it have a positive feel when you switch on and off?
2. How long had you been using the vacuum before it stopped working?
Oct 28, 2010 | Bissell 3750 Lift Off Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
DC14 Animal Vacuum Smells Like Mildew When On
try clean with baking soda clean all the filters with and dry out hot sun so midew dosent get chance grow in the filter
Jul 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
As mention
a little always make sure your filters are clean.but the biggest problem will be with the belt and the brush roller.if it smells like wires burning then its probably the motor .reach up under the front where the roller is but unplug first and see if you can turn the roller by hand.if it turns real freely then the belt is bad.there should be a little drag o the roller when you turn it. i would take the bottom open depending on what kind of vacuum you have and take the brush roller out and clean it real good.holding the brrush try turning the ends and see if they turn easy,if not there is probably carpet strands or hear wrapped around it in the inside of the ends,if you can't turn the roller you need to buy a new roller.if its just the belt replace the belt but before you do clean the motor shaft usually when a belt goes bad there is burnt rubber still on the shaft ,if you don't clean the shaft your new belt will not last long
May 03, 2009 | Vacuums
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
261 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
