Question about GE Ovens
Cleaning cycle completed. lights out. stop timer popped out. how long do I wait until door latch will release. I pushed button but door won't unlock. it's 1 hour now.
    Master:
    Sergeant:
  • 385 Answers
The door will not unlatch until the oven temperature cools down to about 300 degrees.It can take several hours.
Posted on Apr 08, 2011
Oven latch will not open
Sometimes the latch arm is bent causing the latch release not to clear the hook on the door. If the arm goes under the front it is probably bent. Carefully pull the arm back toward the locked position and try to bend it back a small amount and see if the door will open after moving the arm back to the open position. If that fails sometimes you can insert a bent coat hanger between the door and the latch hook and move the latch enough to unlock the door. I hope this helps
Nov 28, 2013 | Ovens
Oven door latch will not release so that I can open the door
Try jiggling the door by the handle. Jiggle it hard, both sideways, in/out and up/down. The little piece in there that releases the door may just be stuck, and didn't move quite far enough to let the door open. These things happen.
Nov 28, 2013 | GE Profile JTP18 Electric Single Oven
Frigidaire door lock won't reset
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
Apr 02, 2013 | Frigidaire GLEB27S7A Electric Single Oven
How do I turn off?
Just open the oven door and you'll see a button that the door actually pushes against... with your finger hold the button in and turn the oven on to the self clean cycle... While still holding the button wait a few seconds and then turn the self cleaning cycle off, this should disengage the door latch... Always keep the button engaged until the self clean cycle is off...
Mar 25, 2013 | Ovens
Yesterday I "self-cleaned" by oven.
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Feb 18, 2011 | Jenn-Air Ovens
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
Self cleaning oven won't unlock after cycle is complete
Unplug it for about 30 minutes, plug it back in and see if it unlocks. If not, then the latch, interlocking microswitch or control board is faulty. Also look for any bad connections (make suer the power is off before you start wiggling connections).
May 21, 2009 | Ovens
1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Feb 18, 2008 | Ovens
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Ovens Logo
43 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
