Question about Stanley CT10C Heavy Duty Staple Gun/Cable Tacker
Won't staple, the staples move and their appears to be nothing to keep them in place
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
brainyass
  • 242 Answers
SOURCE: LOAD IT
On this model, there should be a spring on the arm. Compress the spring and put the staples in. When you close it, the metal part on the end of the spring holds the staples tight.
_____
I
I
I arm and spring below
I___
___I staples here I_____))))))))))))))))))))))))))))))))))))))))))))))____[___]
Posted on Nov 10, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
New electric arrow stapler et501. Will shoot a staple but when you reposition to shoot a second wont always fire off. Sometimes can shoot 2 or 3 in a row and then then will not shoot. gun does not...
Check the instructions for cleaning and lubrication tips. Sounds like you have a buildup of the adhesive that holds staples in "sticks," and it's keeping the staple stick from moving forward into the firing position.
Oct 16, 2017 | Heavy Duty Arrow Et501 Electric...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
The staples don't come out. I have taken it apart
Make sure that the driver blade is all the way up to top of travel (push driver up with thin tool). Load staples and check that the first staple moved into position by looking down nose. If the driver is all the way up out of the way of the path of the staples and staples do not move into place check of debris or wrong staples. If first staple is in position fire nailer several times. If only one staples then miss, driver is not returning to top. This is usually caused by poor seal at the bottom of cylinder, cracked lower bumper or piston orings are too tight or too loose. Good luck
Feb 27, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
How do you load the staples
at the back of the staple gun is a clip you need to move this down from the lock position like a lever, the back will then slide out for placement of more staples, then slowly slide into place and place the clip back into lock position. hope this helps.
Nov 20, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
Stanley Sharpshooter electric staple/nail gun-Hi-Lo knob moves
This is an ongoing problem with this tool. Between inadvertently moving it while using it and the constant rebound of the tool, the setting gets changed. The only suggestion I have is to duct tape the setting wheel into position.
Feb 12, 2009 | Stanley Staple/Nail Gun Elec
Safety
Never let a youngster play with the staple guns. Even the manual ones eject staples with a great deal of force. If something is strong enough o enter solid wood, it is too dangerous for kids. Keep these locked up or in some safe place away from the kids. Keep the safety latch on at all times when you aren’t using it. This will prevent accidents but remember not all staple guns have this feature so you may want to look into finding one that does if you have children around. Of course, you don’t point the gun at anyone else and you keep your fingers out of the way of the staples. With a little common sense, stapling can be a fast, safe and simple way to do all kinds of repairs and projects around the house.
Aug 27, 2008 | Arrow FASTENER CO T50XP "NAIL SET...
Stanley CT10C Heavy Duty Staple Gun/Cable Tacker Logo
184 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
