Question about Haier Heating & Cooling
Hi I have a Haier Through-the wall Air Conditioner (12000BTU)< the compressor turns on, but the unit does not cool. What can i do before I call Haier Customer services? The product is still under warranty, we got it in april.
  • 182 Answers
Id call them right away.dont mess with things and take a chance of voiding the warranty.
Posted on Aug 06, 2008
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
How do i put freon into my 12000btu haier standalone unit
These are sealed units a charging port (tap valve )would need to be added , first clean unit and verify a refrigerant shortage . Remember these units are sealed and require no added refrigerant unless there is a leak. Test for difference between air entering unit and cold air coming out and this should be 20 to 25 degrees for a clean unit ,and if you get this temperature difference no extra refrigerant is needed !
Oct 02, 2014 | Haier CPN12XH9 Portable Air Conditioner
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
Haier hwr06xc7 window unit a/c: fan works, compressor turns on, but just blows room temp air (which sucks when it's 114 deg here). can this model be charged? is there something else i can check first...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Haier HWR06XC7 Air Conditioner
My air conditioner has power but only the fan works no cool air is coming out is it broken, or can I fix it?
sound like the compressor is not turning on if this is Wall unite they are worth investing money into buy anther one.
Jul 07, 2009 | Haier HWF05XC5 Air Conditioner
Compressor turns on but unit doesn't cool.
take the air filter out and see if there is a dramatic improvement - if so clean the air fitler - otherwise it may need regassing
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Friedrich air conditioner stopped running. I was trying to find what the air conditioner was causing to vibrate near the unit. I moved the power cord while the air conditioner was running, pushed the...
This is very possible. Whenever a compressor is unplugged it should rest for about 5 minutes before turning it back on. This is because the refrigerant needs to balance. Otherwise a large amount of amperage may be required to start the compressor as it tries to compress to much refrigerant at one time. I would first check the main breaker for that outlet before jumping to any conclusions. Then let it cool completely before trying again. If this still does not work, you may need to bring it to a service center.
Jun 30, 2008 | Haier hwr10xc6 Air Conditioner
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Central air conditioner doesn't turn on... Any suggestions?
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation. If your central air conditioner doesn't go on automatically: 1) Be sure the thermostat is set to "cool" and set below room temperature. 2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse. 3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off. 4) Turn off the power to the air conditioner and check the thermostat. 5) Remove the thermostat's cover and unscrew the wire from the Y terminal. 6) Turn the power back on. 7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
