Question about LG DLE2514 Electric Dryer
My LG Tromm electric dryer has no power. I turned it on and it ran for a few min. and just turned off. I have tried the breaker and also unplugged it and plugged it back in but no luck. Is there a reset button on it I can try?
  • LG Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Apr 08, 2011
My dryer is an lg tromm dle7177rm. it is 220v. it has ran fine for 3 years but now trips the breaker within 5 min.
If your breakers are old. I'll start by replacing the breaker to the dryer at the box. It is a common failure. Breakers wear out to. Check the power cord for any burnt markings and look at the outlet as well for burnt or discolor contacts. This will overheat as well causing the breaker to exceed the limit and trip it.
Nov 05, 2015 | LG Dryers
DLE9577SM Power issues. Control board?
  1. Power the dryer OFF and unplug it from the electrical outlet (You can also trip the circuit breaker if that's easier).
  2. Press and hold the START/PAUSE key for 5 seconds while the unit is without power.
  3. Turn the breaker back on, and power on the unit.
Mar 29, 2017 | LG Dryers
How may belts on lg tromm dryer
The start button is a momentary start button. It energizes a relay type switch to keep power on. Try holding the start button in for awhile and do not let go. If the machine keeps running, then for sure, the relay type switch is defective and needs to be replaced with a new one.
May 24, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 01, 2010 | LG DLE2532W Electric Dryer
The dryer won't turn on. I have tried the circuit breakers, unplugged and plugged back in the dryer. The dryer was bought in March of 2008.
Check the power cable connection inside the dryer. If that is OK then the defect lies with the power cord. Check it is not twisted or cut in the body of dryer.
Jan 23, 2010 | LG DLE2516 Electric Dryer
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG tromm electric dryer not heating up
Most likely you have a bad electrical connection, resulting in only 120 volts to dryer. (enough to run the 120 volt motor, but not enough to power the 240 volt heating elements) Turn off breaker. Make sure wires on breaker are tight. Make sure nutral wire is tight in breaker box. Take cover off dryer recepticle and check the wires in it to make sure they are all tight. Check that the connections of the cord at the dryer are tight.
Nov 04, 2008 | Whirlpool GGW3878J Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG DLE2514 Electric Dryer Logo
330 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
