Question about Miller Spectrum 375 X Treme Plasma Cutter 907339
My Miller Spectrum 375 Plasma cutter will only keep a cutting flame for about 10 seconds. If I let off the trigger and then pull the trigger again it again will stay lit for about 10 seconds. No fault lamps light. Tip is clear. Air pressure ok. Voltage selector correct. Help
  • 19 Answers
SOURCE: my plasma 375 miller doesnt cut star fashin the
The air pressure may be too high. It should not be at more than 80 psi
Posted on Aug 11, 2009
SOURCE: how hard is it to change out the main circuit
The replacement of a board is no TOO hard, just DRAW a Diagram of ALL connections when you take the "Old" one out. NEVER work on the machine live Duh, also always wait a bit to allow capacitors to discharge, or use a shorting stick, if in a hurry. Anyhow, make sure you keep all fixtures together note down all connections and label them with little stickers, With any other information on the stickers as need be. I always do this as one never remembers whats what after a bit, anyway. Just be methodical, and you will prevail.
Posted on Feb 25, 2010
  • 5603 Answers
SOURCE: spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Posted on Mar 04, 2010
SOURCE: can i plug my miller spectrum 1000 plasma cutter
no you idiot! the plug is different & even if you could somehow, its half the power output. Your plasma welders for the matter, have whats called a duty cycle, which plays into effect.... electrical load level....ect.
HOWEVER-- you can plg ito the same outlet as your stove, washer & dryer plugs. DON'T BURN YOUR HOUSE DOWN, The wife will kill you!
Posted on Sep 05, 2010
SOURCE: how much does a circuit board cost for a miller
depend the circuit boar but is be twin 500 and 700 usd
Posted on Feb 08, 2011
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
Miller 375 x-treme fires about 30 seconds then stops it doesn't stay running, no trouble lights...
Have you watched to see if the pressure light comes on right before shutdown? If so you may need to add a tank right next to the torch base to address the pressure drop assuming your air source is able to deliver adequate volume to the cutter continuously and you currently have more than 25 feet of hose between cutter and compressor. It might not hurt to check the internal filter as well.
Dec 29, 2011 | Miller Spectrum 375 X Treme Plasma Cutter...
When you start cutting it will cut about 2 inches and kick out you let off the trigger and pull it back on it will do the same as long as you do that it will not cut continusle please advise does not...
You may need a better air supply. Also check the tip. This sometimes happens with mine when the tip gets pitted, not sure why but changing the tip sorts it out. They are fussy machines in some ways. Dont like dirty material, need a good earth.
Aug 31, 2011 | Miller Spectrum 375 Cutmate Plasma Cutter...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
Pull the trigger ,air comes out no fire
Ck the ground and the condition of the tip. The more it gets concave the harder it gets to get a arch. Gun angle is also important, hold at right angle to work and don't forget a very good ground.
Nov 03, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 X Treme Plasma Cutter 907339 Logo
128 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
