I have an wansa tv living in kuwait, AV1 is hook up to SaTELITE, AV1 AFN DECORDER BOX AND AV3 DVD/ VCR THE AV3 IS A BLUE SCREEN HOW CAN I GET IT TO WORK
  • 52 Answers
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Posted on Mar 04, 2008
SOURCE: NO AV1 AND 2 VIDEO SIGNAL
tv start working on its own.
Posted on Jun 27, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Posted on Dec 31, 2008
DickCanFixIt
  • 948 Answers
SOURCE: need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Posted on Jan 01, 2009
SOURCE: Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Posted on Feb 22, 2009
How do I get sky tv through my philips mx5100vr home theatre
External Input Mode (for VCR features) To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Apr 25, 2015 | Philips MX5100VR System
How do i reset av and tv chanel on Samsung Series 4 PS42C430 42
i activate av1,av3 and av3 in service. my tv come on and off. i can't inter in service. samsung 42, PS42C430, SO HELP ME HOW TO DEACTIVE AND INTER IN SERVICE.
Jun 19, 2012 | Samsung PS42C430 42 Plasma TV
I have a General Electric tv that someone gave me. I hooked up my dvd player and programmed it play on channel 3. I says no signal when I try to play a dvd on channel 3
There may be a chance you have hooked it up to play on AV3, as opposed to CH3. There should be an AV button on your remote or the TV. Press it a few times and see the channel flicks through the AV channels. They are usually AV1, AV2, AV25, AV3, AV35. Look for AV3, or for your signal on any of the other AV channels.
Mar 02, 2011 | Televison & Video
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
Im trying to hook up my new lcd tv using a cable box and a dvd player but cant find any diagrams. As of now I can get a picture but the sound is low and can only be turned up by the cable remote. Any help...
it should not be a big deal red and white is sound yellow is video, if you have a converter box and are not getting a signal I would suggest you try moving your antene to get picture. Try hooking the DVD plaer into the TV to AUX 1 or AV1 or AV 2 Or AV3 and make sure the TV is on the right channel on to see Picture and correct level of sound, are you running anything threw a coverter box? Need to know the TV brand to do a diagram. The output from the DVD player shoud go into AV1 and the wire colors should be the same DVD output to AV1 input or AV2 in?
Jul 06, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Hook up vcr
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Split screen question
Ah split screen just another way of getting two picture in one screen, or sport for he and Opra for her.
Fisrt you must understand what split screen is, it is taking two information from different source and sending the info to the micro to devide the info for two seperat image.
Well something like that but I know you were inpress,
Yes you can. Take the main source you or using I would say the TV box in cable connection or av1 and then your DVD or and VCR to source av2 or 3. When presing split screen or pip you will get one screen showing the main source your tv box and the second your dvd (or VCR) in the source input solector you should be able to change the second amage input with input solector and the tv box change the other.
Oh what a butiful life aint it.
Try this with 7 different source, Cable, satelite, fta, dvd, camera, gaming sytem, and computor,... well that another chapter.
What about Bob
Feb 29, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
