Question about Freud FT2000E 3 Router
I,AM LOOKING FOR A POWER SWITCH FOR MY 2000E PLUNGE ROUTER
  • 710 Answers
You can order your switch from Freud at (800) 334-4107. It is number 42 on the parts breakdown which you access at: http://www.freudtools.com/images/manuals/FT2000VCE.pdf
Freud's part number is 76325.7001
It doesn't seem like anyone stocks Freud parts. Went to some discussion sites and found that even repair centers don't stock them. You'll have to contact them directly.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 08, 2011
  • larry_boccio May 08, 2011
    Hello Wentlanv, My name is Larry Boccioletti I am a canadian parts and service rep for Freud westmore tools operating out of Milton Ont Canada.I have that part in stock I can and will also send you a I.P.L. for that tool if you wish at no charge .
    I am sure I can help you.Contact me at larry_boccioletti@yahoo.ca if you are interested.
    Regard
    Larry
    New Friend:
  • 25 Answers
Hi There My name is Larry and believe it or not I am a freud dealer in Toronto Canada and I have parts for freud ft2000 routers--and I have a switch in stock send me an email if interested. Thanks
haltonmaintenance@yahoo.ca
Posted on Oct 16, 2016
Looking for DeWalt DW625 router manual
Make a quich search on google. I found several links where you can download the manual.
Sep 27, 2014 | Dewalt DW625 3 Hp Vs Elect Plunge Router
I need a 1/4 collect for FT 2000e Freud plunge router, where can I buy it?
Hello Freddie--my name is Larry Boccioletti. I am a Freud parts supplier from Toronto Canada.It is almost impossible to get parts from Freud in the states---because Bosch has bought them out.
I have parts for the ft2000 and FT3000.
If you would like a quote I would be happy to get one for you.
just send me an email to haltonmaintenance@yahoo.ca
Larry
Apr 06, 2013 | Freud FT2000E 3 Router
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada larry_boccioletti@yahoo.ca
Sep 11, 2011 | Freud FT3000VCE Router
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
I just received a 693 plunge router via internet order. As soon as i took out the plunge part out of the case and moved the lever it pupped up and now will not move up or down > Is there something I am...
The plunge base is spring loaded. When you move the lever is springs to the up position. To lower it place the base on a flat surface, press and hold the lever down and push down on the handles. The router bit height should be set on the depth rod with the base in the down position. Then release it to the up position. When you have positioned the bit where you want it on the work piece, press the lever and "plunge" the bit down into the workpiece. The depth rod setting will stop the bit at the depth you set it for.
Oct 21, 2009 | Porter Cable 6931 Plunge Router Base For...
Reversing switch on 2000e gearbox
it is located on the side of the gearbox either on the rear extension housing or in the middle main gearbox housing it should have 2 wires comming out of it
Apr 12, 2009 | Ford Escort Cars & Trucks
Where can i get a new switch for the 2000e?
OK the switch I found that you need is part number 76325.7001 and to find it I would suggest going to Freudtools.com and they have a dealer locator on the home page, if you have trouble give me your location with zip code and I will find one for you. Good luck
Mar 11, 2009 | Freud FT2000E 3 Router
Freud 3 one fourth plunge router variable speed won't run
Hi
First check the power suply cord(conductivity),the on/off switch, the fan and the armature,the brushes and the wires.
best regards savumihai71
Jan 05, 2009 | Freud FT2000E 3 Router
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
1613EVS Plunge Router will not operate. Does not start !
hello- had same problem with similar model-- problem is definitely DUST INSIDE THE SWITCH, it must be blown out with compressed air- i had this done at a repair shop (for free) so i don't know if they had to disassemble anything- hope this is helpful
john
Nov 16, 2008 | Bosch Plunge Router
Freud FT2000E 3 Router Logo
338 people viewed this question
Top Freud Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
jairo sanchez
Are you a Freud Tool and Hardware - Other Expert? Answer questions, earn points and help others
