Question about GE Simon Commander 3000 Security 8zone 60-672-95-8z
I have a "GE Security Command Center" alarm system
  • 78 Answers
SOURCE: Westinghouse Security System beeping
Hi, as you know your system is old. The company that made your system no longer exists. There is no support for your system. No parts available. It sounds like a circuit board problem. Defects in circuit boards are not normally fixed where I work. Not cost effective to pull panel and send it out to be bench tested. shipped back for reinstallation. cheaper to replace panel and keypads. There is a 50/50 chance you may have to replace sensors Too, on that panel. Hope this helps.
Posted on Sep 09, 2009
  • 34 Answers
SOURCE: ge 429c esl 4 wire smoke detector won't quit
you may need to clean the chamber.
Posted on Dec 01, 2009
  • 15 Answers
SOURCE: re wiring after someone disconnected
red and green is the phone in and the brown and grey are the phone out thats all u need make sure u connect it to the main line into the building as the pannel needs to have priority on the line
Posted on Mar 29, 2010
  • 74 Answers
SOURCE: ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
Posted on Aug 23, 2010
  • 74 Answers
SOURCE: I have a GE home
It might not hurt to try the "Microsoft Solution" and reboot the system. First disconnect the AC power then disconnect the battery. Wait 1 minute then reconnect the battery and reconnect the AC power.See ifyou can arm and disarm the system. Then reconnect the siren and try again to arm and disarm the panel. If the keypads beep it can usually give you an error code that will help you pinpoint the problem.
Posted on Sep 05, 2010
Alarm is going bananas in the high winds. Can i disconnect it?
The electronics are complex.
I would advise you not to tamper with the alarm system as that is likely to trigger the security/immobilise system and stop you from starting the car.
I would take the car to a Jag service center and discuss some options with them for either fixing the problem or disabling the alarm in manner that will not cause problems with the security system.
Dec 16, 2015 | 2002 Jaguar X-Type
GE Security Command Center - alarm sets off for no reason.
how many zones do you have on the alarm system? if its more than 8 your problem might be due to a faulty expander that is used to create more zones on the alarm panel. repairing these are not worth it as a new one would be cheaper.
if this is not your problem it might be due to a faulty pacife or beam. go past each point and check if the light goes on when it detects movement. if not replace the unit.
Nov 04, 2013 | Home Security
Low cpu battery how do i fix it on alarm system
Open the system, unplug the transformer, disconnect one lead of your battery, reconnect the battery first, then the Ac if it says low battery still, then you need a new battery take the one you have go to battery plus get a new one, and reconnect it, it may still say low battery, wait for an hour for the battery to charge, disconnect the AC and battery again, reconnect the battery first then the transformer. It should clear the low battery.That battery is a
6 VDC 1,.9 Ah.
Mar 11, 2013 | GE Security Simon 3 Wireless Home Security...
Drive medical phoenix 3 backup alarm
It is very easy to quiet your backup alarm. All you need is a small philips [+] screw driver and a piece of electrical tape about 1 inch square. Raise the "hatch cover" under your feet by removing the two small phillips head screws on either side of the raised edge. Locate the small round black son-alert taped in line with one of the wiring harnesses. You will see an opening in the center of one side of the Son-alert. That is where the "beep" comes from. Prove you have the correct part in hand by turning on your key switch and pressing the horn button, first with your finger over the hole in the son-alert and then without your finger covering the hole. You will hear a very big difference if you have the right part. Now you can put your piece of electrical tape in place over the hole and try it again. It will be much quieter. DO NOT CUT THE WIRES LEADING TO THE SON-ALERT! If you still want it quieter use a thicker, more sound deadening cover over the hole, but cutting the harness to disconnect the sona-alert entirely will lead to unintended consequences.
Jan 30, 2012 | Drive Medical Phoenix 3 Wheel Compact...
I recently installed a GE Simon XT wireless security system. It worked fine upon initial installation. However, I decided to relocate the panel. At the new location I had to extend the transformer lead to...
Check the outlet to ensure it :1- has power , 2- is not a switched outlet. Check your wire connections to ensure they are secure. If all of the above are good, the transformer may have shorted when disconnecting. Use a voltage meter on the transformer terminals and the AC scale, check the output of the transformer.
Apr 27, 2017 | GE Security Simon 3 Wireless Home Security...
How do I change the battery in the GE Simon XT panel?
If your system is monitored call the central station first and tell them you are working on it. Then push down on release tab in top center to fold down the front face. Nest step is to use a small flat blade screw driver to push in and release the tab again in the top center and the unit will fold down towards you, hold on to it and you will see the battery compartment. Follow the red and black wires to the battery. Some units have a plastic lid over the battery that requires you to remove to small phillips screws to remove battery.
Feb 21, 2010 | GE Security Simon 3 Wireless Home Security...
Vista 15 pmt security system. I'm not sure how to replace the battery. I want make sure I don't set the alarm off or get shocked during repalcement. The battery is a CA 1240 12 volt 4 AH Casil. The system...
If you attempt to disconnect the battery the alarm will go off and you may not be able to reset it. there is a specic code to be set before any maintenance can be done. These codes are all different otherwise there would be no security!
Any alarm company would be willing to change your battery and if its a monitored alarm they might also want to take on your monitoring. Call an alarm or security company in your area for assistance
Aug 17, 2009 | GE Security Simon 3 Wireless Home Security...
Disarm car alarm
Simply disconnect the power leads to the alarm...........sodeep
May 11, 2009 | Vehicle Parts & Accessories
Westinghouse Security Systems
an easy fix is to get a dsl filter for your system and reconnect it back up to the telephone line.
http://www.safemart.com/Alarm-System-Essentials/Z-Blocker-Alarm-DSL-Filter-1EZ-A431PJ31X.htm
and no ido not work for Safemart.
if this doesnot help you email me...
mj
Jul 22, 2008 | GE Security Simon 3 Wireless Home Security...
GE Simon Commander 3000 Security 8zone 60-672-95-8z Logo
806 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
