Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I am trying to connect an xbox to my Toshiba REGZA TV but have been unsuccesful. When i hit the input button to try and change modes to Video 1 or 2 i am unable to access them on the menu as they appear "hidden".
  • 643 Answers
See if you can unlock inputs by going to a Rename input option.
Posted on Apr 09, 2011
I have sound but no picture the menu still displays just nothing from any video inputs its a toshiba 47hl167
I am assuming you have already tried leaving it unplugged for 15 minutes and then trying to restart it. Does it work in the TV mode? I.m not sure if there is a rest button on that model. If you go to Toshiba Support there might be more info.
Apr 12, 2015 | Toshiba REGZA 47HL167 TV
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
I dont have cable.i was using this tv just to play dvds and i accidentally hit channel search. now i get a blue screen that says" plerase connect cable system or an antenna to the terminal on the back...
Hi:
Using remote locate a button called tv/video or Input, turn on the DVD player and hit this button until you see your DVD player Logo. Most dvd players use either video 1 or 2, or componet or HDMI outputs. Seems you have changed the TV's input back to TV mode and you need to change it to a video mode input.
May 17, 2011 | Televison & Video
TOSHIBA REGZA 24" LCD/TV cannot
"JUST PRESS CINEMA MODE ON YOUR REMOTE CONTROL AND SELECT APPROPRATE VIEWING MODE" it might be located under the left of 0 with an image like stretching as indicated on my remote. It is the issue about the overscanning and underscanning of tv using HDMI connection. I have been the same problem as you but I did solved it using this. Hope this would help!
Mar 10, 2011 | Toshiba REGZA 47HL167 TV
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
Tv/video mode with no remote
you should have a menu button on the
frount of the tv press it and then select
with the (ch up) (ch dn) to highlight the
input/sorce or ant select with the enter
button then (ch up ) ( ch dn) highlight
video 1 or 2 press enter .
If this was not helpful tell me the
model # and look it up on my data base.
Rob
Sep 21, 2009 | Microsoft Xbox 360 Console
No remote and channels won't set
Hi Roberta :)
There are a number of possible problems that can be the cause here lets go over them and see if you can deduce your problem.
The first thing I think of after reading this is the Video 1 displayed on the screen. On the back of your Tv and front sometimes there are 1 or 2 Coaxial Inputs, as many as 1-6 Componet Inputs (Red White and Yellow) and maybe some others if your tv is newer such as HDMI or S Video or Infrared port or something.
Take a look at your tv and count the total inputs (you will have 1 ouptut component for recording purposes). Each one of these has on a Television a "Source" or "Input" mode. if you can get through the menus with buttons to anything that says source or input try and manipulate that setting this may flash between these "sources" or "inputs" and show different screens (one might be cable one might be DVD player if its on, one might be Static and several could just plain be empty.
If you are unable to do this try unplugging the device for a few mins, then press the power button to discharge power in the unit. now plug it back in and see if the T.V. enters a setup mode where it scans for channels for cable or resets the input possibly.
Again if this is unsuccesful you can post your T.V. Manufacturer and Model and ill find you a model of universal remote that you can purchase that will be compatible with your tv
Comment if you trouble persists.
Please rate this help
Brad
Apr 12, 2009 | Sanyo DS27510 27" TV
Channal selector down
Sounds like it is changing to another video mode that has no input so the screen is blue. On many tv's the channel buttons also act as video input button. This should happen with the buttons on the tv. If you are using the the remote I am not sure why it is acting like a video input button. Try changing video to tv with one and changing the stations with the other. I take it you are watching antenna tv and not using cable box or satellite. If this does not work and you have old vcr just use it as a tuner to change your channels.
Aug 03, 2007 | Toshiba CX35F70 35" TV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
314 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
