I have a MSI MS 7228 Motherboard in a computer that i was changing power supplies on and the front panel wires pulled loose. I need a manual to determine where the wires connect back. There are no markings on the MB indicating the switch locations so the manual appears to be the only solution. Any help would be appreciated.
    Problem Solver:
  • 13 Answers
Msi Motherboard MS 7616 start up
check power supply and the front panel pins look for all plugs for power are in the right plugs
Dec 09, 2013 | MSI Computers & Internet
Msi ms 7297 ver.2.1 front panel help
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels;
PWR power
RST reset
HLED hard dive LED
PLED power LED
You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
Jan 06, 2013 | Intel Motherboard
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
Jan 05, 2013 | AMD MicroStar MS-5191 Socket 7 mATX...
Need a schematic to wire front panel on n1996 ms 7061 motherboard.
1) http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=bph07557&lc=en
2) http://h30434.www3.hp.com/t5/Desktop-Hardware/Getting-a-new-case-i-need-Front-Panel-pinout/td-p/842897
Scroll down to the photo, and pinout, of a 9-pin HP Front Panel header
(No.9 pin. Reserved. It is/was, reserved for the factory.
5 Volt DC test point. It is N/C. Not Connected)
Nov 26, 2012 | MSI : MS-7061-020...
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
I confuse for front penal on off switch connector
Here is a link to MSI for your MS-6378 Manual.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
The file is in .zip format and will need to be extracted to view its contents.
Connector JFP1 pins 6 and 8 are for the on / off switch. Pin 6 is power switch high reference pull-up. Pin 8 is power switch low reference pull-down to ground. Information from page 2-17 in the manual.
Jan 31, 2010 | MSI MS-6378 Motherboard
Front Panel Connections for motherboard
Is that the right motherboard number. You can download the manuals from eu.msi.com
Jul 07, 2009 | MSI MS-6580 Motherboard
MSI MS-6154VA wiring diagram
MS-6154VA Mobo Manual here
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=338
Nov 17, 2007 | MSI MS-6154VA Motherboard
Computers & Internet Logo
549 people viewed this question
David Payne
David Payne
