Question about GE Heating & Cooling
Why would the fan motor be burning up on zonline air conditioner, model #AZ58H09DACM1. Only 3 months old.3 different ones in a year
    Problem Solver:
  • 9 Answers
From my past experience, if this is a wall zoneline, it may not be tilted back enough for the water to drain and it is shorting the motor out because of too much water being slung around in the unit while running.
Posted on Apr 09, 2011
Testimonial: "that may have been the reason for one of the units because it was just cleaned out and it wasnt dry all the way. but the other 2 werent wet"
First time starting a/c this season, display is lit but no air is blowing. Fan outside is on. Batteries changed, still no air. System is only @ 2 years old. Stat model - TH3110D1008. Thanks.
Set the thermostat FAN setting to FAN ON to verify the fan working.
If it works in the FAN ON position the fan motor is OK and you have a bad fan relay.
If it does not work you should check the fan motor capacitor.
At 2 years old the unit is still under warranty for parts.
Apr 26, 2011 | Honeywell Heating & Cooling
My PAC25 had a burning smell come from the unit and now when i turn it on i hear the hum of the compressor trying to turn but nothing else happens. it is a few years old and out of warranty so is there...
The burn smell is the fan motor cooking. I have the same unit and upon strip down the motors windings were fried. Now that hard part of finding a replacement.
Nov 18, 2009 | DeLonghi PAC85 Portable Air Conditioner
I have a Colman Model #6283-801 Central Air Conditioner. The fan burned out and I was told they no loner carry the fan motor. Is there a compatible motor.
Call and ck ith Walts RV in Fontana if you are in This area. They may have one. They know the RV parts business real well.
Sep 17, 2009 | Whirlwind FH-778 Air Conditioner
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Jul 05, 2009 | General Electric Heating & Cooling
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
2 fans have burnt out in less than 1 year
I would say the motor is pulling to much amp draw.When you install it watch you place the fan blades in the air steam.May be you are moving to much air and that will make the amps go up and cause the motor to over heat.Also hope you are getting the same hp and rpm.
Apr 05, 2009 | Heating & Cooling
Condensor fan motor
you have a reversible motor or a two speed motor check the old motor for speed and rotation
Jul 29, 2008 | Goodman CLQ36AR49 Air Conditioner
Soleus kfr 18gwda
The fan blade can be purchased by calling 1-888-8soleus.
Mar 11, 2008 | Soleus KFR-18 Air Conditioner
Heating & Cooling Logo
145 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
