Question about Cameras
My Pentax Optio 60 takes great photos. Recently, though, I have not been able to use it because fully charged batteries don't power it up. The lens extends and immediately goes back into the camera.
  • baskets Aug 07, 2008
    I went out an bought a lithium battery and, after installing the two batteries the camera powered right and stayed on! Thank you. So far so good. How long is the service good for? For only one tech problem?
    Master:
  • 623 Answers
Ounds like battery problem to me,try replacing it with new ones ni-mh batteries works best for me
Posted on Aug 06, 2008
  • 876 Answers
It does sound like a power problem or perhaps you have the camera set in the wrong mode?
  • 928 Answers
Remove the battery and then put it back in. After that reset the camera back to factory defaults. Try it now, if that does not work I would suggest you take the camera to an authorized service center as something inside may be stuck
    Genius:
  • 1,689 Answers
Have you tried using other type of batteries specially Lithium Ion, i personally would use them long life. anyway aside from batteries, if you hear any noise while gently shaking the camera, it may mean somehing other than dead batteries. you may also want to check on the contacts of your battery chamber, check for rust and other elemets hindering the battry to provide power to the camera.
should you have other questions, just let us know.
hope this helps - voodoomox
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
I have had my pentax potio 60 for over ayear but hardly used it. Now i want to use it. i had tried many times to charge using the recommended 2 AA batteries but does not charge. or after taking a single...
Hello.
The Pentax Optio 60 does not charge batteries. You must purchase a battery charger and rechargable batteries and charge them yourself.
The AC Power Adapter cable just powers the camera, it does not charge the batteries.
Hope this helps.
Feb 15, 2010 | Pentax Optio 60 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Pentax optio 430.
the focus assembly is not working . will have to replace lens assembly to make work correctly .
Apr 18, 2009 | Pentax Optio 430RS Digital Camera
Pentax optio e60 lens error 0x04110000
je viens de resoudre le probleme sur mon pentax E70L avec un simple aspirateur domestique,a l'aide du tuyau le plus fin, en realisant un nettoyage minutieux, tout autour de l'objectif, (sans rien demonter, evidemment!), ensuite le code lens error a changé, puis j'ai continuer a ouvrir et fermer l'appareil, a tenter de changer les options "scene", et l'appareil ne s'est pas refermer !...et j'ai pu refaire des photos!...soulagé!...l'appareil n'avait pas 2 mois!..mais rappelons nous qu'il n'aime pas le sable!
Mar 17, 2009 | Pentax Optio E60 Digital Camera
Pentax Optio A30 - turns off when I zoom in
This might sound a bit silly, but as I have posted earlier I had a similar problem As soon as he lens came out ready to take pictures it retracted and turned off. Because i haave decided to buy another camera I held the Optio in my right hand and banged it into the palm of my left hand. No great shock to the camera, but hey presto it now works. Not sure if I can rely on it though......what does anyone else think about this?
Jan 25, 2009 | Pentax Optio A30 Digital Camera
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
Lens extends after power, then buzzes, then goes back in and shuts off. It was working not too long ago. And I haven't dropped it. But I just tried to use it and it doesn't want to work. The battery seems...
Go to this website: camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera
I couldn't fix my Pentax Optio S10, but this is the best web site I found to address the problem we both have with lens extending, buzzing, then shutting off. I took my camera apart, and found that my lens was cracked around the edges.
Nov 01, 2007 | Pentax Optio S7 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
