Question about Whirlpool RBD305PD Electric Double Oven
Does an electric oven need curing before I cook in it for the first time? If so, how long and at what temperature?
  • Whirlpool Master
  • 2,696 Answers
You can run it at 350 for like a half hour or so and you'll smell a funny smell from the metal heating up,when i replace an ignitor or an element i run it for like 10 minutes just to burn off the smell of the metal.i'm sure the factory already had that fired up to check it but i would start it and burn anything off of it that might be in there before i cooked anything,it can't hurt it.good luck with your new machine.
Posted on Apr 08, 2011
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    My oven does not heat to the correct temperature. If I set it for 325 degrees it will heat to 390 or so degrees. It always seems to be about 70 degrees too high. Accross all ranges of temperatures from...
    The thermostat is the cause of the problem, normally the the only cure is to replace the oven thermostat,completely, or alternatively, compensate by setting a lower temperature when cooking.
    this will work o/k if it is always the same variation in temperature across the range .
    Dec 25, 2010 | Electrolux 30" Built-In Single Electric...
    I get an F1 symbol on mt electric oven
    The F1 error code usually means the oven temperature has exceeded the safe limit for the oven.
    Usually this is an indication that the temperature sensor has failed 'on' allowing the heating element to overheat the oven.
    You would need to have the temperature sensor replaced.
    Jan 13, 2010 | Maytag 30 in. Electric Single Wall Oven...
    Gets hot too quickly food cooks too quickly
    no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
    Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
    Oven temperature increases 50' after original temperature is reac
    What it needs is a new oven thermostat fitting, much cheaper solution than buying a new oven, it is a fairly straight forward repair, if you require more details let me know.
    PLz rats my solution.
    Thanks.
    Jan 03, 2009 | Whirlpool RBS305PDS Electric Single Oven
    I AM COOKING MY TURKEY AND AN F10CODE COMES UP CAN I CONTINUE OR WHAT
    F10 on Kenmore ovens means Runaway temperature error, it means that the probe sensor detected overheating.
    Stop the oven and allow cooling for one hour or so, with the power cord unplugged.
    If error is still there, then you will need to call the technician and have parts below checked and eventually replaced.
    http://www3.sears.com/imaging/ImageP...&titleID=00003
    Part#316217001
    About the turkey, see if you can borrow one of your neighbour's oven to finish cooking, or leave it half baked and put it back into the oven if the oven restart after cooling up. Remember that you will need to add some more time to the total cooking time, as the turkey will get cold inside.
    Good luckshow?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
    Nov 27, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    OVEN TURNS ON BUT WONT HEAT UP.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
    T3 electric wall oven - Temperature set buttons
    I had the same problem. The entire control panel had to be replaced. That included the display, keypad and all the hardware behind it.. it's one integrated unit. Luckily I had the extended warranty, otherwise it would have cost close to $400.
    Jan 20, 2008 | Maytag 30 in. Electric Single Wall Oven...
    Oven taking a long timt to heat to temperature
    Try shutting off the breaker for about 10 minutes - then bring the power back on
    Sep 20, 2007 | GE Profile JT912 Electric Single Oven
    Whirlpool RBD305PD Electric Double Oven Logo
    85 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
