Question about Ovens
I am looking for an owner's manual for the Jenn Air JJW8630DDW double oven. I purchased one but it did not include the manual. The unit is like StarWars and I can't figure out how to use all of its features properly. Thank you. Gloria
  • Ovens Master
  • 17,970 Answers
Visit this link to download: Jenn-Air JJW8630DDW Oven Manual (PDF format).
Also, here can find the Installation Manual.
Hope helps (remember to rate this answer).
Posted on Apr 08, 2011
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
Sep 24, 2015 | Jenn-Air WW30430P Stainless Steel Electric...
Have a jenn-air jdr8895aab double oven. the oven panel just shorted out and have no controls for oven. can i just replace oven panel?
Call Jenn-air
1-800 # should be on the inside of oven
They may beable to send one to you if YOU can install or refer a local applaince repair shop for the unit ?
Oct 12, 2013 | Jenn-Air Ovens
How does one rmove the oven door of a jenn air oven. I can not find instructions in the owners manual or installation guides/instructions. Do I need to remove the hinges or is there a release mechanism?
Look at the hinge, their is like a slider bar to move or you remove the little cover plate, with the Philips screw..then lift the door up and out while pulling...
I WARN YOU, if you really don't need to remove the door don't, it is very hard to put back on unless you have had practice....
Dec 19, 2010 | Jenn-Air Electric Double Oven
Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jenn-air double oven that is level for cooking on the bottom but the top oven is not level. I can't find manuals on the oven. Is there an adjustment between the upper and the lower oven. Do you...
First check to determine if your cabinet face is plumb (level), as sometimes that is the problem. If the entire face of the cabinents are plumb on both side, you'll likely need to either shim the top edge of the upper oven section or remove the oven and readjust the leveling adjustments (or shim the rear of the upper oven assembly), depending on just how far off the oven is from being plumb and level.
I've tried searching for the installation manual for your oven and found three (3) possible model manuals that could be helpful. I've included the link to the Jenn-air site so you can look at each and glean which one would be the most helpful for your issue.
The link will show the owners manuals and installation instructions that should apply for your situation.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JJW8230D&siteCd=JA_EN_US
Jul 13, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jen air double oven
Convection ovens shouldn't be dripping anything. If you are making moisture-laden foods and the vent on the unit is clogged...even partly, you may have an issue. Inspect and clean. Pull the breaker!
Nov 20, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn air 2001 double oven , light display is out...
it would be nice to figures this out but i have not. the light unit or the power supply unit is bad but i don know which. both units cost about $150 each. so you want to be sure when yoou order your part which is bad
Nov 07, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Ovens Logo
88 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
