Question about Chi Ceramic 1 inch Flat Iron GF1001USA
Gets hot then shuts off - Chi Ceramic 1 inch Flat Iron GF1001USA
  • 38 Answers
Most flat irons come with a safety setting where as soon as they get to a certain temperature, they shut off (to keep the customer safe). Try turning the setting down to a medium-hot. Also, if it stays on for a long time it will shut off by default to help with accidentally leaving it on. 1. Try turning the heat down 2. Don't let it set for long 3. Try hitting the reset button. Sometimes the settings get shifty, so resetting the device can sort out the problem. 4. If none of the steps work, take it back. There is something wrong with the flat iron, like a short in it.
Posted on May 22, 2011
System shuts off after 5 min will start again if turned off and on but only plays for 5 again
It sounds to me that something is getting very hot and causing the system to shut itself down. Then when it cools off, it returns to normal. Investigation inside straight after it has shut down might reveal what is getting hot, by simply feeling for a very hot part. But be careful don't burn yourself!
Sep 18, 2015 | Audio Players & Recorders
Why would it get hot once coex cable hooked up and scanning for channels? tv gets hot and shuts off.
I would check that there is not a problem with the power supply to the set. If it gets hot and shuts of the power may be faulty and could be causing component failure.
Jun 05, 2015 | TCL LE48FHDF3310 48" LED TV 1920x1080, 120...
Gets hot shouts off
could be coil getting hot and shutting down, or fuel pump getting hot and doing the same
Aug 19, 2012 | 2000 Oldsmobile Bravada
Car shuts off when it gets hot
your ignition coil are going bad, they need to be replaced. once the car gets hot the circuit shut down the car when hot. once they cool your riding again until they get hot. thats your problem. Good Luck
Jul 31, 2010 | 1988 Buick Electra
Is there a thermostat shut off switch . car runs
The amount that it gets hot is a clue but theres no shut off switch. It's possible that the car is over heating and the temp gauge does'nt have enought water over it to report the problem. once the cooling system is cleared as it's full circulating and the fan will come on when it's hot ( disconnect the temp. switch on the therostate cover on the top of the transmission, ( the stat is in the lower hose ) with it disconnected and the key on the fan should be on and connected f till it's real hot. The crank senser or distrubutor module can can too hot and shut down too
May 13, 2010 | 1997 Toyota Corolla
Hi,water at shower head not hot although hot side of valve is getting adequate supply must be mixing with to much cold however high temp is set on valve,Any tips,thanks
the valve where they mix is blocked on the hot side, or the shut off is almost shut off. check the shut off first.
Nov 13, 2009 | Home
Car got hot and shut off. I was hoping for a fuel shut off switch of some sort in the trunk or a fuse block/circuit breaker or something easy. Any suggestions?
if it only shut's down when it gets hot and won't start until it cools down it sounds like the ignition module is getting hot and breaking down
Nov 04, 2009 | 2001 Buick Century
Engine shuts down when it gets hot.I have replaced the coil,tuned up with pionts and plugs.Also removed intake and resealed it.I'm wondering now if it has something to do with the govenor.It seems to just...
i am not a expert just trying to help,it sounds like it is vapor locking,, check your gas lines to see if they are getting hot,,and check to see if carb. is getting hot maybe be a exhaust leak causing gas to bubble hope this help
Oct 04, 2009 | Garden
Chi Ceramic 1 inch Flat Iron GF1001USA Logo
652 people viewed this question
Top Chi Health & Beauty Experts
ray gallant
Don A
Don A
Are you a Chi Health and Beauty Expert? Answer questions, earn points and help others
