Question about Home
The motor sounds like its working but the jets aren't. Could they be clogged?
  • 43,501 Answers
Not likely....
It is more likely that the pump has an air lock or the pump has come apart internally...
Try turning off and on a few times, if that does not work then the pump is probably broken...
heatman101
Posted on Apr 08, 2011
Washer fluid motor not working
it can only be these things. (is just a dc, motor)
does it spin? does it make noise, ( we know it dont pump liquid)
but???
Ill pretend motor is silent.
1: bad fuse #6
2: bad pump, bad motor. (same unit) pump can in fact jam with junk and be silent. clean it.
3: bad wires connectors to same or bad washer switch
NOT SILENT.?
motor tries to pump, (ear by sides, and cleaned inside by you)
A: clogged line,or any check valves seen in line, on most cars. clogged.
B: kinked line.
C: clogged jets.
Dec 03, 2013 | 2007 Honda Fit Sport Hatchback
Strating PROBLEM
Hi, Andrew and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Why won my SYM Jet motor scooter start
Scooter Troubleshooting Scooter won start All about Scooters
Sym Jet 50 Service Manual
SYM Sanyang Scooter Parts Racing Planet USA
Sym JET 50 series Owner Manual
May 09, 2017 | 2007 Sym Jet Euro X 50
Wiper fluid comes out sparingly and not all the time, motor works
Be sure you have 12 volts at the pump motor, and that the pump intake is not obstructed. Then, make sure the jets are not blocked on the hose side, as the jet diameter is smaller than hose diameter. I would remove the hoses at the jets and the pump and blow air backwards through the system. Also, blow air backwards through the jets to insure they are not clogged inside. Replace all hoses and try system, if no change, then the pump itself is bad, probably a bad impeller in the pump. This should fix the problem...Good luck.
Jan 24, 2013 | 2004 Acura TL
Haritage softail will only run with choke on
Make sure the intake seals aren't leaking or the main jet isn't clogged.
Jun 03, 2012 | Motorcycles
I have a eclipse 8203 and the jets aren't working
see if voltage to pump if voltage replace pump if no voltage bad relay
Jun 02, 2012 | AO Smith Pool & Spa
The chair has not been used in quite a while. I charged it and it did work. Now I hear the motor going but the chair does not move the brake is off
Check to make sure that the freewheel levers aren't in freewheel. they have to be in the drive position for the chair to work Hope this helps
May 03, 2011 | Jet 3 Ultra Power Chair
Motorcycle/dirtbike/ttr225/starting problem. Is not getting gas to sparkplug.As long as i put gas in sparkplug hole motor fires until burns gas out.
sounds like your pilot jet may be clogged, or your needle valve is stuck shut, remove the float bowl and check it out. (the pilot jet will be the smallest one, and the needle vavle will be attached to the plastic float assembly.
Apr 07, 2010 | 2002 Yamaha TT-R 225
When i turn jacuzzi on it primes and one of the pumps/jets turns on, then when i try to turn the other jet/pump on it makes a funny sound and blows a fuse i checked to see if any air is in the line but...
This is probally a bad motor, the sound you hear is the motor trying to start but when it can't the breaker trips. If it takes a start capacitor it may be this rather than a motor but you will have to pull the motor to see. It may also be a clog in the pump but the motor sounds like the problem.
Sep 29, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Mantis tiller won't run at high rpm
check the carburator, it sounds like a main jet is clogged or the carburator is dirty. Is the air filter clogged? Is the motor under strain?
Jul 03, 2009 | Mantis 2-Cycle Tiller
Once tub is filled. The whirlpool jets do not work. Do not know if they could be clogged or not. Only hear the sound of the motor.
The impeller in the pump has probably been broken......a costly fix as you can only get a new pump to fix thins.
But just for kicks and giggles......check to see if the intake isn't clogged. Remove the filter/strainer and see if anything is blocking it.
Probably not but it is a free and quick check
Apr 14, 2009 | American Standard Home
Home Logo
138 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
