Question about Toshiba Computers & Internet
How to remove all data from computer - Toshiba Computers & Internet
  • Toshiba Master
  • 27,725 Answers
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
Posted on Apr 08, 2011
Why all things are come in my data traveler in shortcut ?
Your Data Traveller has plugged with a Shortcut Virus infected computer.
Use Shortcut Virus Remover,
It will remove all shortcuts from your Data Traveller and will recover your data back.
Shortcut Virus Remover download link - Shortcut Virus Remover
Oct 05, 2014 | Computers & Internet
Tip
How to remove data from computer permanently
When you leave your job or just want to remove your personal data form your computer so no one can recover it try free open source program called Eraser.
It is an advanced security tool for Windows which allows you to completely remove sensitive data from your hard drive by overwriting it several times with carefully selected patterns.
You can download it from here.
on May 07, 2010 | Computers & Internet
My hard drive was removed from my dell xps 420 with out the data being backed up. Is there a way to recover the data and programs? or is the computer now junk?
computer is not a junk if u install new HDD i sould work...to back up ur data u can visit a local hardware tech and he can guide u....only if u are not able to use that HDD in any other PC to remove data
Feb 13, 2012 | Computers & Internet
Not showing ther data
Insert the Memory Card to the card reader,
Then plug the card reader to the computer and perform the following setting to the computer.
Go to the Control panel,
Choose Folder Options
Then click on View.
Choose
Show hidden files and folders
and
Remove mark to the Hide extensions for known file types.
Again
Remove mark to the Hide protected operating system files (Recommended)
A Warning will Display Click OK.
Then Apply and Click OK.
Open My Computer and Go an Open/Explore your Memory Card for Backup of your data.
Copy a Data to the Computer and Format your Memory Card.
Before Restore you backup to the memory Perform the setting of file attribute to your data
Example of file Attribute is
Read Only
Archive
Hide
Right Click your Data
and then Remove a mark to the Hide in Order to view Your Data to the Memory Card.
Thanks a lot.
More Info; Rogerftn@gmail.com
or
Call
+255 755723228
Jul 05, 2011 | SanDisk 2GB microSD Memory Card
My computer went bad and I cannot get the data off of the storage drive. How do I proceed?
Hello Sir, hi, to access the hard drive data, you need to get the Hard drive out of your computer and place it on another computer.
to remove the drive. 1. power off the pc. 2. open the side panels to access the inside. 3. locate the Hard drive. the rectangular metal unit in front. not the CD drive okay. 4. remove the 2 cables connected to the drive. power and sata/ribbon cable. 5. loosen the screws. 6. Gently pull out the drive.
Ask a friend with a computer to help you out to get the data. or visit a computer shop to have your data back up tp a CD bring you drive along.
May 22, 2010 | Maxtor Shared Storage II (S01R320) Hard...
How can I open a backed up file from the external hard drive? Bottom line - I really do not understand how to use the product? Or how to learn how to use the product? Also, I had backed up data from my old...
1 st how find ypur back up data
my Computer folder you will find your Extanal Hard open that you will find your all date copy from your HDD and copy where u want to use
to remove your date from your PC just go to my Computer and click on your drive wright click you will find formate just click that one box will open from that select quick format then click on start it will delite all your data
Apr 13, 2010 | Western Digital Passport WDXML800UE...
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Feb 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer is not reading USB hard drive
Check out this blog post by these flash drive professionals:
http://www.flashdrivepros.com/_blog/USB_Flash_Drive_Data_Recovery_Blog/post/Help!_Windows_No_Longer_Recognizes_My_Flash_Drive!/
...and if that doesn't help, you can always order their cheap service. Its great that they have a guarantee, that if they can't recover your files for you, then they'll give you a full REFUND.
Feb 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I don't know how to save to the kingston 4GB USB2.0 data travelter - no instructions with it
You just plug it into a USB port and your computer will automatically detect it.
Please rate this solution and thanks for using FixYa
Jan 06, 2009 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
