Question about Bosch Dryers
My dryer is not turning - Bosch Dryers
  • Bosch Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Apr 08, 2011
My dryer turns on and runs for only a minute. It then turns off and will not turn back on. It is like there is an element that gets too hot when turned turned on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 16, 2011 | Kenmore 500 6952 Dryer
When I turn on dryer I hear a clicking sound and the dryer turns off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Kenmore 72062 Gas Dryer
My gas dryer will not turn the clothes drum the dryer turns on but the drum does not move
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 11, 2010 | Kenmore 62602 Electric Dryer
Dryer turns on does not turn
heatman101
Jul 06, 2010 | GE DWSR463EGWW Electric Dryer
My dryer won't turn on at all. It was working
heatman101
Jun 19, 2010 | Kenmore 66832 Dryer
Dryer will turn on but but the inside will not turn
heatman101
May 19, 2010 | Whirlpool GEW9250 Electric Dryer
REX4634KQ Electric Dryer: dryer heats up but won't turn...
heatman101
May 18, 2010 | Roper REX4634KQ Electric Dryer
Whirlpool gas dryer, the dryer turns on but will
heatman101
May 12, 2010 | Dryers
Dryer lights up but will not turn
heatman101
May 12, 2010 | Whirlpool WED8300S Dryer
Dryer does not turn and shuts breaker off when turning dryer on.It just makes a noise as if it's trying to turn.
heatman101
fsgs
Apr 06, 2009 | Estate EED4300TQ Electric Dryer
Dryers Logo
62 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
