Question about Western Digital WD HDD 500GB SATA 25" WD5000BEVT 500 GB SATA Hard Drive
I have a 500GB external drive that when plugged into computer, a messege comes up that says, ' One of the usb devices has malfunctioned and Windows does not recognize the driver and to try plugging it back in', this has never happened and it does this with all other computers. This has all my movies and music and pictures, what do I do? Hockeestud1@gmail.com, Thanks- Eric
  • Western Digital Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Posted on Apr 08, 2011
I lost my Hitachi 500gb driver, can I get a driver so as to recognizing it with windows 7.
Just connect it -- it is a Plug-and-Play device, and Windows 7 supports Plug-and-Play.
Do you get any error-messages when you connect it?
Does it connect to some other computer?
Does some other USB device connect to the USB port that you're using for the Hitachi?
Dec 18, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
How can I power up my seagate 7200.11 500gb external h/drive to my pc
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Oct 03, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
I have 500GB SimpleDrive USB 2.0 External Hard Drive, but currently i am facing some problems with it. When i plug it in to my computer, the computer says that unknown device. and it also does not come to...
I would unplug the external drive then shut down your computer. Plug the drive in(be sure the USB port is in good working order.)Turn the computer on. If it does not recognize the drive search online for tech support for that particular drive. Install any drivers or software. Be sure to find out if the drive is compatible with your operating software. Make sure all connectors are seating firmly and correctly. Make sure that everything is plugged in where it should be plugged in.
Feb 15, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
VOX 500gb won't connect to PC.
Go to Utilities and format the drive for Mac.
May 19, 2017 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
Describe your SimpleTech 500GB is not a 250GB
You should not have to install and extra drivers for this device as Windows XP should find this device when you plug it in to the USB port. Try plugging it in to another USB port on your computer. Plug another device in to the USB and see if it works.
When you say the plug and play feature does not work, do you mean that Wndows does not see the device or the backup program is not working?
Mar 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Can't get it to work
What operating system are you running? Windows Me or older has troubles finding plug and play external hard drives sometimes. If so look up some how to's on google for installing your model of external hard drive on to the operating system you're using. Although if you're using XP or Vista you may have an issue in your Device Manager. In that case you will need further instructions.
Jan 22, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital WD HDD 500GB SATA 25" WD5000BEVT 500 GB SATA Hard Drive Logo
185 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
