Question about IBM ThinkPad T41 Notebook
Fan Error - IBM ThinkPad T41 Notebook
    Problem Solver:
  • 20 Answers
Fan error usually means the fan isn't working and may cause the system to overheat and destroy the intell chip. Probably need a new fan and it will be expensive to get done and hard to find someone to do it. Ask IBM for help.
Posted on Apr 08, 2011
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
HLM507W #1 Fan Problem
Yes the set isnt recognizing that after market fan thats why the Fan error is flashing.
Jul 12, 2009 | Samsung HLM507W 50" Rear Projection HDTV
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
127: fatal error
Fuser Unit Fan Error
When an error has been detected in the fuser cooling fan
Mar 17, 2008 | OKI C5150n Led Printer
IBM ThinkPad T41 Notebook Logo
196 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
