Question about Jacuzzi Pool & Spa
Top side control is new,circut board is new has power but will not come on.
  • 310 Answers
If you know you have correct power to the board, and you know the top-side control is meant to be used with this board, then you got a bad board, or control unit plain and simple.
Posted on Apr 08, 2011
Left earbud has no sound
I had this problem with 2 of my HBS 700s. The speaker in the earbud goes bad and needs to be replaced. If it is still under waranty you can send it in to be replaced (trying a home repair will probably void your waranty so try this at your own risk). If it is out of waranty and you have experience with a soldering iron, the earbuds can be replaced with a plain set that look similar to the originals from your local store (Wallgreens has a good selection for like $10). I am a novice at these things but the solution was pretty easy and has worked for both of my earbuds. I actually improved the quality of sound by installing better earbuds.
3d9a9467-2679-44c4-ba93-679ba93f6b9d.jpgYou will need:
- 1 small soldering iron
- one set of new wired earbuds (no volume control or mic... just plain earbuds)
- jewlers phillips head screwdriver
- one small flat screwdriver or thin flat edge to pry the cover off.
- one needle or thumbtack
Directions are the same for both sides. I suggest doing one side at a time and repeating the steps for the other side.
Directions:
- TURN OFF HBS 700
- locate the rubber plug on the bottom of the case (one on each side above the L and R symbols) and remove the plug with a needle.
- remove the screw located under the plug
- use a jewelers flathead screwdriver or thin flat edge to pry the case appart. The best method is to gently pry the bottom of the case outward then push in and up on the top part of the case starting at the back of the plastic case (where the earbud wire comes out) and working your way forward.
- remove the earbud cup and set aside. (if working on left side, also remove the charger door.)
- the circut board is held in place by plastic arms on the sides. Gently pry the circut board away from the case and lift up where the arms are holding it in place.
- once case is removed from circut board, you will see where the earbud soldered to the board.
NOW FOR THE FUN STUFF...
-cut your replacement earbuds to length and expose about 1/4" of the two wires inside (usually one gold and one colored or one solid color and one multi colored).
-The two wires are coated to prevent them from shorting out while touching. Add solder to your soldering iron so there is a good drop hanging from the tip. Insert one wire at a time into the drop of solder (about 1/32" will do) and hold it there for a few seconds. This will melt the coating and allow the solder to stick to the wire.
BE CAREFUL NOT TO SOLDER TOO MUCH OF THE WIRE OR IT WILL TOUCH THE OTHER AND SHORT OUT! ONLY A LITTLE ON THE TIP OF THE WIRE WILL DO.
-carefully use the soldering iron to remove the old earbuds from the circut board. A small soldering iron with a sharp tip works much better than the standard size at this. The soldering points for +/- are VERY close together so becareful not to melt them together.
-solder the new earbuds in place of the old ones. + to + and - to -.
-tie a knot in the earbud wire close to the circut board so it does not pull free from the case when closed.
-at this point in my repair, I turned the HBS 700 on to listen for the startup tone to make sure the earbud was connected properly. I DO NOT RECOMMEND TURNING IT ON OR TOUCHING COMPONENTS WHILE IT IS ON. IF YOU WISH TO CHECK IT AT THIS POINT LIKE I DID, DO SO AT YOUR OWN RISK. ALSO, MAKE SURE NOT TO HOLD THE CIRCUT BOARD OR TOUCH IT WHILE IT IS ON AND TURN IT OFF BEFORE CONTINUING.
NOW IT'S TIME TO PUT IT ALL BACK TOGETHER.
-reinsert the circut board to the top cover in reverse of how you took it out. Do not force it and make sure all the plastic arms clip over the circut board securely. Make sure to press the buttons to see if the are seated right.
-replace the earbud cup, battery door and power switch if it fell off.
-attach the bottom cover making sure to leave the knot on the inside of the cover. The cover should snap on easily.
-Re-insert the screw and plug.
DONE!
If you wish your new earbuds to attach magnettically to the cup, you will need to break open the old earbuds and remove the magnets from inside. Then glue them to the outside of the new earbuds or drill a hole for them to sit in and glue them in. Be careful tho because drilling holes too deep in the new earbuds could damage the wires inside (I found that out the hard way)
I hope this solution was helpful
Oct 17, 2013 | LG HBS-700 Bluetooth Headset
Have a aprilair 550 for some time. Installed a new Lennox G61MP furnace and the technitions failed to reconnect the wiring that powers the humidifier. Need wiring schematic. Does humidifier transformer get...
Hello, yes the transformer will get a 120 volts from the Furnaces control board, there should be a terminal labeled HUM on the control board. You need to bring 2 wires one from HUM and one from a nuetral tap on the board to the line side of the transformer, this way every time the blower motor on the Furnace turns on the humidifier will aswell.
Aug 23, 2011 | Aprilaire 550 Humidifier
Have 240 volts to circut board but does not power up pump and control panel
so you have power going to the control box but nothing comes on...check the voltage coming out of the transformer. May be that is all that is wrong but may still require a new circuit board.
Jan 26, 2011 | Home
Photocopier fuses hi my name is redha i would to have a definition of fuse in the photocopier in general the location and tha function ASAP Please Thanks
Redha,
Fuses are located on the power supply and some control boards.
In general fuses are used for circut protection when the load exceeds what the circut is capable of handling the fuse will blow to hopefully protect the circut and the board. This is a very broad definition.
Hope this helps
Apr 18, 2010 | Gestetner DSc338 Copier
My truck has lost electrical power on the left side for the drivers's power seat, power adjuster pedals, and power mirror control. There is power at the fuse and the fuses were replaced with new ones,...
It is at the grounding screw, remove, clean, replace, clean batery terminals too, Clean engine grounding screws, check all grounding screws.
Vitally
Sep 15, 2009 | 2004 Ford F150
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
Rear turn signal bulb on passenger side of 1997 GMC Yukon needs to be replaced, how do I do this.
Open your rear door and on the inside jam where the light is remove the two screws.There either a philips or torx head.Rotate out a little and litely pull the other side tabs out of the notches in the quarter panel side.Once you remove the light you will see a circut board with two more screws.Your bulbs are on the inside of the circut board.If your new bulb doesnot work,you may need to replace the circut board,there known to burn out.Hope this helps.John.
Mar 09, 2009 | 1997 GMC Yukon
Control panel dead, door is locked
heres a few ideas.
1 first check your power going to the machine the plug, inspect wires leading up to it.
3 if you are sure the control panel is dead order a new one and replace it pretty easy. only if you are sure.
4 last resort - take the top off it to get to the latch. if the latch is on the top, make sure. you should be able to get the latch from here,if not you have to take the front off too,which is a pain.
most likley the circut board in the control panel is bad and i think you have to order the whole thing, i think. remove the screw in back and look to see if any circut board can be removed by itself. to replace the controls its just a matter of a few screws and plugging things back in order.
Feb 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Color Problem after replaced Circut Board
When you replace the entire board in a Zenith TV, you must make the adjustments to align the new chassis with the old picture tube. You must adjust the CRT bias and drives as well as the horizontal and vertical parameters. On the older boards there were controls on the main and CRT boards but on the newer boards the adjustments are made with the remote control after entering the service mode. Tune in the shopping channel QVC, set the color and contrast to minimum and lower the brightness until the picture is just visible. Set the CRT bias settings for a pure black and white image, then increase the brightness and contrast to get a very bright picture and if necessary adjust the drive settings so that the bright picture is pure black and white. Return the video settings to normal and then adjust the vertical and horizontal settings so that the info boxes on QVC are centered top, left and bottom. If you are not sure that you can do that right then have a qualified tech handle it for you.
Jul 23, 2007 | Zenith SY3572DT TV
Pool & Spa Logo
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
