Question about iLO Televison & Video
Remote suddenly does not work. new batteries put in
    Problem Solver:
  • 18 Answers
Also You can visit for new remotes: www.remotes.lt
Posted on Apr 13, 2011
  • 718 Answers
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
In the USA look at; www.remotes.com
In the UK look at; www.remotesrus.co.uk
http://www.findremotes.com
http://www.espares.co.uk
Posted on Apr 08, 2011
My Element remote control suddenly stopped working. I put in new batteries but that didn't work. My TV is a 32 inch HD Digital LCD TV. Please help! Ginny
Please don't think me rude or ignorant, because I am far from it, but possibly your batteries are incorrectly fitted maybe? Or it could be complete remote control malfunction, you can buy universal remotes quite cheaply but take your tv's make/model/serial number with you to check its comparability, hope this helps
Dec 30, 2017 | Element Televison & Video
The remote for intelliseat doesnt work, even with brand new batteries. Any ideas?
My remote worked but the blower would not respond. If that's the issue, take the label off the remote (the corner by the heater button) and put a piece of aluminum tape over the contacts so there is a better connection. I also got a new one from AMDM (under warranty then) but I am still using the first remote I fixed. AMDM customer service: 1-800-778-1450
Feb 13, 2015 | AMDM Intelliseat - The Ultimate Bidet...
My comcast remote was working with my Motorola dct700/us box and now suddenly stopped working
Put in new batteries or check that the battery contact points inside the remote are free of rust or acid build-up from leaking batteries.
Dec 06, 2013 | Arris DCT700 DTV Receiver
My samsung un55b8000 remote suddenly stopped working! Can it be reset or do I need a new one. Still lights up when picked up.
Take the battery out,wait like about an hour.Put in new batteries.That is ur reset to the remote control.Still have the same problems,the remote CPU chip is dead or dying.Sorry,than ur remote is garbage now.Try website like Remotes.com to buy an exact or very close to ur original remote.
Nov 08, 2010 | Samsung UN55B8000 55 in. LCD HDTV
ALL OF A SUDDEN MY REMOTE ISN'T WORKING. I CHANGED A CHANNEL AND NOW NOTHING. CHANGED THE BATTERIES AND TRIED TO RESET THE CODE. STILL NOTHING. HAVE A PHILIP MAGNOVOX. ANY IDEAS?
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Jun 12, 2010 | RCA RCU403 Remote Control
Remote don't work properly
Remove the batteries, open your remote clean the pcb (with cotton ball slightly damped in rubbing alcohol) the one that is painted green as well as the carbon contacts the one behind the remote pads, let it dry and put it back, replace with a new batteries.
Jun 06, 2010 | Element Electronics PLX4202B 42 in. Plasma...
We have a ge universal remote control for our tv and it has been working and all of a sudden it does not work - we put new batteries and that did not work
Please check & ensure the infrared is emiting from the remote control. Though we cant see this infrared beam with bare eyes, there is a trick to do so in http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html Most of the problems is weakened infared beam. Replace the batteries when needed. Hope this fix the remote control problem.
Jan 03, 2010 | Directed 434MHZ Remote Control
Remote key lock stopped working after wal mart put new battery in and now my head lights stopped workin!!!
check fuse for low beam, then possibly both low beam globes. they could have blown.
the key remote may need reprograming into system try put key in ignition in on position then press remote buttons a couple of times then try if no good need to go to dealer to be programed into system again or it needs repairing/replacing.
May 31, 2009 | 1996 Chevrolet Camaro
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Help...
If you have menu controls directly on your TV. You might try resetting all the settings.
Aug 12, 2008 | JVC AV-24F702 24" TV
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
