Question about Kenmore 62602 Electric Dryer
Electric dryer, runs for about 20 min then shuts down, can restart after a period of time, then runs about 20 min and shuts down
  • 42 Answers
Could be the over temp safety switch. Something is heating up to a trip point, quits and then cools back down to run again.
These switches have two wires and there may be two or three. With an ohm meter and the dryer cool and unpluged measure each switch - they should show shorted or closed. Run the dryer until quits, unplug and recheck the switches. The one that is open is most likely the trouble maker.
Posted on Apr 08, 2011
  • Kenmore Master
  • 2,696 Answers
You have a bad motor,most likely you don't clean out the dryer,this is the number 1 killer of dryers.the vent line,the duct that the lint filter slides into and the cabinet where the motor is needs to be cleaned out if it's gas once a year,electric once every two years.all a dryer does is move air,when lint starts to build up the dryer starts to run hotter then normal from the lint build up and the dryer can't move the air as easy as when everything is cleaned out and then parts start to brake like the thermal fuse will pop from running to hot or the motor starts to over heat like yours and shuts down.when the motor gets hot the oil that's inside it leaks out,you'll see it stuck to the side wall and on the rear end of the drum with lint stuck to it.there's an overload in the motor that pops when the motor gets hot and after a while when it cools down the overload resets,that's why you can start it again after a while so basicly you have to replace the motor and clean out the dryer,if the vent line is a long run,remove it from the back of the dryer and with a leaf blower blow it out,you'll see all kinds of stuff blow out through the outside duct and clean out the duct that the lint filter goes into and the cabinet where the motor is or replace the dryer.
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Air massage runs 20 min. then shuts down. when I restart it right away it only runs a short time.
air systems have a built in timer on them. 20 mins.
they are supposed to be shut off for 20 mins to cool the blower down then can be turned on again.
Feb 13, 2011 | Maax Home
My sears dryer will shot off when iy gets hot,going through its cycle. If i let it cool down for about 10 mins. I can restart and continue for another 20 mins before it shuts down again
Take the exhaust vent off the rear and try it.
If it runs OK,repair the vent blockage/restriction.
If it does not run OK,replace the motor.
Sep 27, 2010 | Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
My whirlpool electric dryer smells hot.
generally if the uint shuts off from overheating and then will not restart for a 10-20 min period of time usually a sign htat hte motor is overheating and needs repalcing
Mar 31, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
140 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
