Question about Refrigerators
I have an LG Refrigerator. The unit is completly dead. The Model number is LFC23760ST. Tried plugging it in several different outlets. still dead.
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Posted on Apr 08, 2011
  • charles Aug 28, 2012
    The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
How do i level my refrigerator it is a LG MODEL lfc2376osb
When leveling a refrigerator you want to have the front a little higher than the back. This will help the doors shut better and allow the water to drain properly into the condensate pan. Your unit should have feet that you lower on the front of the unit behind the front toe grille. They will be on the front corners.
Mar 01, 2015 | LG LFC23760ST Side by Side Bottom Freezer...
Why is my LG french door act like is has no power?
Probably a bad fuse on the main board. Fuse is not replaceable so either you have do a workaround (search LG refrigerator fuse repair for several fix videos and how-to's) or you have to replace the whole control board (part EBR41531302 I believe, but double check with your the part vendor before ordering).
Check the fuse by pulling the refrigerator out, unplugging, taking off back control board panel, and checking the fuse for continuity.
Aug 02, 2014 | LG LFC23760ST Side by Side Bottom Freezer...
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
Jul 18, 2012 | LG LFC23760ST Side by Side Bottom Freezer...
LG Frig LFC23760ST 3 Door French Refrigerator : No power!
LG LFC23760ST
I recorded a 2 part movie clip on how I repaired the blown fuses on my LG refrig's circuit board.
Mar 31, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Our refrigerator LG Model #LFC23760 just quit working. We checked the plug and it is good. Not sure what to do next. There is no power to the unit. Nothing is working.
fuse blew, if you have a contract have it repaired but try to keep the old mother board. (they just throw it away anyway, otherwise they are not authorized to work on LG units) you will see the culprit fuse. have it replaced in an electronic shop, (have them put in a fuse holder) and keep a few extra fuses Just in case... next time you could replace the board yourself.
Feb 28, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
LG LFC23760ST ice maker barely making ice
The making of ice may speed up a bit after the whole unit interior and insulation is cooled down.
Jan 28, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
